  • Legacy Donating Member
  • Member For: 20y 1m 13d
Posted
Hey just got a quote from The Tyre Factory in Dandenong for those of use in VIC.... for $550 fitted... I thought that was a tad high.. Anyway I was told that they were illegal and I had to sign a form for them to fit em... He said the rear ssl springs were illegal but he called them ultra lows instead of ssl... is there a difference cause I have never heard of ultra lows before....
  • Member For: 22y 26d
Posted
get him to double check because ULTRALOWS are different springs again to SSL..
as the name says, their ULTRA low. about another inch over SSL's
Posted
Ok so theres SL, SSL and now Ultra lows....
Just got off the fone with Dandy Exhaust and they quoted me $380 fitted... cheapest so far...
  • Member For: 22y 11m 1d
Posted (edited)
SSL is the lowest spring for the BA. It's in the catalogue. They refer to them as Ultralows.
www.kingsprings.com.au
I have SSL in the rear of mine, and if they made a lower spring, then trust me I'd have em.
Edited by bob^
Posted
suspension city in north melbourne 380 or 350 I got mine done for sl fron and ssl in the rear also tell the guy in dandy to go f*ck him self the tosser
Ok a bad experience I presume
Posted
So if that is correct than... they guy at tyre factory is saying they are illegal....but every1 has got em and are calling em SSL. I dont really care if they illegal cause a stock looking lowered T wont draw too much attention from the boys in blue...
Posted
Also how low will the car be with standard 17's I've only heard from of the boys with 18's and higher saying that bumps aint no probs but with smaller wheels will they be a problem??
  • Member For: 23y 1m 28d
Posted
The SSL's make the car very close to being illegal I think you'll find. The minimum height allowed by the RTA is 100mm from the road to any fixed part of the vehicle. When I had standard SSL's in my car the measurement was pretty close to right on 100mm from the ground to the exhaust heat shield.
  • Member For: 21y 7m 5d
Posted (edited)
This is what it looks like with 17's and SL and SSL
If you are looking at getting 19's though (or larger rims) wait untill you get the rims and tyres before lowering it.
See below pic for 19's with same springs.
The car has raised itself about an inch. (notice the height difference along the sideskirts)
Im going to get custom springs made up to lower it again.
Edited by Bain
