  • Replies 59
  • Member For: 20y 3m 19d
OK ladies, here is my $00.035 worth.
Up until not too long ago I would have said bigger brakes will not stop you any quicker for a single stop from "Normal" speeds, BUT, things have changed.
as you may or may not know, I have aute, heavy little things, they are, I decided to up the brakes with a set of DBA 4000 series gold slotted and cross drilled rotors all round and bendix ultimate pads to boot.
the above set up is Night and day ahead of the crap factory tstuff, how Ford can sell a car with the performance these thing have with the brakes the fit is beyond me, al law suit waiting to happen.
I recently went for a ride in my mate BF Phoon, STOCK auto, 18's, dunnys, brembos (not the big ones).
WOW, is all I can say, the inital bite and hold is unbeleivable, I thought my ute was good, but these pupiies are inreadable, remeber he has the crapp ole sp9000, I am running Goodyear eagle fi jobs, which are a much better tyre, bearing in mind his car is lighter, but it stops Soo much better, and sooner then mine, time after time, mine is good for 6-10 hrd stops, then its all over, his just keeps going.
to sumarize, the theory or tyres being the weak spot in a "normal speed" brake stop is true to point, but the grab the big brakes have, it will bring in the ABS well before mine, which means it is stopping harder and faster, bring heat into it and the game is over.
BIG brakes are a must, I am going to fit some biguns once I finish making it go fast
IF you can lock your wheels….. in your application (your top speed, your frequency of braking, your tyres etc) fitting bigger brakes will not pull the car up in a shorter distance.
However... increasing the power of the brakes may (depending on the brakes) greatly reduce the effort required to activate ABS. As alluded to in the previous posts, the greatly reduced braking effort it may, just may, enable you to activate ABS earlier. There is after all a difference between theoretical maximum performance and sheer drivability. There is a similarity in the arguement with the fact that carmakers recognized a while ago that normal road drivers brake too gently in the early stages of critical braking situations. Consequently, some new braking systems are fitted with systems to detect emergency braking conditions and boost braking power to the full ABS modulated limit.
Now for the fun.
Once you have the optimum brakes for your car, that is optimum for your application so that the brakes lockup whenever you need and with an effort that you can easily apply, adding larger (heavier) brakes can increase the stopping distance of your car. This is because of the increased mass of the brakes. On bumpy ground, the effect is even more pronounced as heavier brakes increase the unsprung mass of the car.
Regards,
aa
Edited by aiboart
  • Member For: 21y 8m 17d
Heres another point from Ford Engineering
Area of science: Engineering
Brakes do not stop cars--not directly. That is why they are called wheel
brakes. The wheel brakes stop the wheel. Tires stop the car. Antilock
brake systems (ABS) stop cars faster (most of the time) because they
prevent wheel locking. A locked wheel typically has a lower tire-road
friction than when rolling with some slippage.
Tire-road friction normally reaches a maximum when the slip rate is around
20%. The reason for this slippage is that the tire is elastic, and must
deform to transmit the tire-road tread force to the wheel. When the tire-
road friction is greatest, this deformation (rolling 'slip') is about 4
centimeters (1.6 inches) for a typical passenger car tire on a good road
surface.
Present antilock brake systems do not optimize the tire-road friction.
However, they do prevent wheel locking. This does two things; it permits
vehicle steering control (very important) and usually increases the tire-
road friction, compared with locked-wheel braking.
If you want to stop a car in the shortest possible distance, you first
should apply the brakes very rapidly. The rotating components of a car,
mostly the wheel-tire assemblies, provide about 5 percent of the vehicle's
kinetic energy. Rapidly braking the wheels helps reduce this energy and
also starts the tire tread deformation needed to maximize tire-road
forces. Since the wheels are directly bolted to the brake drum or disc,
almost any torque can be used. More is better in this operation.
When the tires reach maximum tire-road friction, you then should reduce
the brake pedal force to maintain maximum friction. Experienced
performance test drivers can do this surprisingly well. Some use the tire
sound to help indicate the degree of slippage.
Now you have enough knowledge to answer your own question. Brakes that
are large enough to just lock the wheels (but no more) will complete a
stop as fast as larger brakes. However, larger brakes may reduce the time
to initiate braking of the tires. Since this is at the beginning of
braking (when the vehicle is moving fast), a small savings of time can
shorten stopping distance by a significance amount.
  • My engine bay is Bionic
  • Member For: 19y 1m 16d
The application of ABS is too much brake pressure being applied. ABS should noy be used to stop a vehicle, unless the driver passes the threshold braking point and this safety mechanisim activates. ABS does not stop you in a short distance than not using ABS. ABS in fact increases braking retardation, then not using ABS at the braking threshold point, which is difficult to obtain under stressful braking situations.
  • Member For: 19y 5m 14d
Isn't that excatly why they fit ABS in the first place :censored:
  • Sucker
  • Moderating Team
  • Member For: 21y 10d
Isn't that excatly why they fit ABS in the first place :fool:
:msm:
Took alot of getting used to with my first ABS equiped vehicle, but I'm not to precious to admit that if I need to stop in a hurry the brake pedal gets full downforce applied. Who cares what a professional race driver would be doing in the same situation.
  • Member For: 20y 2d
:spoton: No probs here with stomping on the pedal when needed - I just want the bloody car to stop, and fast!! :spit::spoton:
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 22y 1m 20d
:laughing: No probs here with stomping on the pedal when needed - I just want the bloody car to stop, and fast!! :crybaby::laughing:
Only time I ever used ABS was in Dad's Sprint and christ was I thankful for it! Bloody Kangaroo on Dusk! I am no where near skilled enough to bring a car to a stop quicker than what ABS can.
Lumpy :laughing:
  • Sucker
  • Moderating Team
Sooo can we all agree that bigger feet help you stop quicker.... :glad:
Nope.
The alloy pedal covers on the BF don't agree with size 15 dress shoes :pinch: Takes a few seconds to get the f*ckers untangled first :kissmy:
