  • Legacy Donating Member
  • Member For: 20y 4m 6d
Posted
Bought some new Cadence splits on the weekend ( yes, impulse buying haha ) and thought I could just rip out the JBL 6in driver and drop the cadence 6incher in... nope, no chance of fitting as the baskets are heaps bigger.
So, Needing to build new baffles to mount the 6s on I decided to make them as big as possible and seal up the doors for the best bass I could get from them.
Some 16mm mdf and a roll of stick on sound deadening stuff from bunnings ( yes, too tight to buy Dynamat ) and this is what I ended up with...
It sounds awesome, so much better than the poorly mounted JBLs I had in there. Theres loads of bass up front from these new speakers and they work well with the subs... the subs accually sound heaps better to so there must have been so massive cancelation at cetain frequecies.
First pic is the JBL 6 waiting to be evicted!
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 20y 4m 22d
Posted
Hey RAP1D did you have premium sound to start off with because I have found with my 15 in the boot that the rest of the standed speaker's are ok, apart from the front splits?
Cheers
Michael
Posted
Yeah I still use the premo, just the subs run off a mono block. The amp in the premo has ok power and sounds very good
  • Colossal Member
  • Member For: 22y 1m 2d
Posted
Cool, I cant view the pics cos of mozilla (wtf) but sounds like you are on a winner there. How much was the sound deadening? How rigid is it?
Posted
60 for a 144mm by 10m roll. its thinner than dynamat but its nice and dead, heavy too
  • Colossal Member
Posted
Sounds good, I'll have to go have a look at some for mine... I get a fair bit of loss in the doors with the MBs...
I might also look at putting some in the sub box to make those walls a bit more dense.
Posted
Yeah its definatley worth the effort. I'm going to cover the boot lid and boot walls on the weekend
  • Member For: 22y 4m 18d
Posted
Let us know how the boot goes with this cheaper deadening... im to tight to buy the real thing so a cheap effective alternative is the way to go for me...
ahahahaha
  • Colossal Member
Posted (edited)
RAP1D: Did you have any issues with re-fitting the door trim after adding all the shizzel? That piece holding the woofer is quite large... any reason for making it go all the way to the bottom of the door?
And what dit you mount the crossover to? Did you have any dramas running those wires? It's damn fiddly pulling apart the grommet that goes from the door to the cabin :spoton:
Edited by XXXR6T
Posted
Yeah I had to trim a bit of the door trim, just all the little flap like things that stick up 10mm.
I made the panel fit into the cut out section of the door trim, basically wanted to make it as big as would fit to stop any flexing. Its needs to be as solid as posssible for the best sound.
Wiring wise I used the stock wiring into the doors and extended it to reach the xover... just used the wire that came with the splits.
I mounted the xover with the deadening tape... so once I had covered the big gaps with 2 layers of deadener, its was stiff enough to suport the xover and I just used more deadener as tape to hold it on, and its on solid but with a bit of give to absorb bumps
