BF_Turbo Member 236 Member For: 18y 1m Gender: Male Location: Central QLD Posted 05/08/07 01:48 AM Share Posted 05/08/07 01:48 AM Use an oxy torch and warm it up a little bit...... can you video this so I can get some clear instruction as well.. Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561275 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 20d Gender: Male Location: Perth Posted 05/08/07 02:01 AM Share Posted 05/08/07 02:01 AM (edited) being that the fittings are steel and the filter body is ally they are probbaly siezed. Try tighening the fittings slightly first. This can help to free a galled thread. Also get some "penetrene" its basically kero and petrol mixed together. the petrol helps the kero to wick into the thread. Failing that i would take to the filter with hack saw and cut the threads from the filter. Then split them length ways to free the thread. A small smear of an antisieze compound woul probably stop this happening again... Edited 05/08/07 02:02 AM by hiddeous Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561278 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 4d Gender: Male Location: Perth, NOR Posted 05/08/07 04:31 AM Share Posted 05/08/07 04:31 AM I tried the oxy torch suggestion, but it made my car explode... and other suggestions? heheI'll give it another shot today and try tighten it a little bit then go for it again.I think the fact that my jack only lifts the car up so much, and it only gives me a little bit of room to work with under the car doesnt help. its very hard to put a lot of force into it when the car is only like 1 inche above your chest. Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561306 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 30d Gender: Male Location: Dé·jà vu Posted 05/08/07 04:57 AM Share Posted 05/08/07 04:57 AM I think the fact that my jack only lifts the car up so much, and it only gives me a little bit of room to work with under the car doesnt help. its very hard to put a lot of force into it when the car is only like 1 inche above your chest.You might wanna read this thread as well then....Jack Collapse - A Warning Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561312 Share on other sites More sharing options...
SavageF6 Donating Members 1,622 Member For: 21y 1m 25d Gender: Male Location: Sydney Posted 05/08/07 05:48 AM Share Posted 05/08/07 05:48 AM Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561323 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 11m 5d Gender: Male Location: The 8th Dimension Posted 05/08/07 05:56 AM Share Posted 05/08/07 05:56 AM Never work under a car with just a jack, you are just asking for trouble.Jack stands are cheap insurance. Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561324 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 5m 21d Gender: Male Location: Brisbane Posted 05/08/07 06:37 AM Share Posted 05/08/07 06:37 AM Could this thread be worth making a sticky out it? Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561329 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 9m 20d Location: Brissy Posted 05/08/07 09:45 AM Share Posted 05/08/07 09:45 AM Changed mine last week, the stock pump came out easy but once you install your new one check for leaks, check for leaks and check again had to undo and tighten the new one 3 times before it stopped dripping, freakin box said something like low torque flange, low torque my ass, had 2x spanners squeezin the faaark out of em to stop it drippin. Dunno Maybe I just got a dud or damage flange. Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561404 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 4d Gender: Male Location: Perth, NOR Posted 05/08/07 12:05 PM Share Posted 05/08/07 12:05 PM You might wanna read this thread as well then....Jack Collapse - A WarningI dont have a set of jack stands yet, but im using a decend jack (not a standard ford one) and it may sound stupid, but I laid my 4 x 17" rims underneath the cars chasis so if the jack failed the car would be sitting on the tyre/rims. Id rather damage those than my head I know its stupid, but I wanted to get the job done that day. I think I'll invest in some jack stands next weekend however Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-561478 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 4d Gender: Male Location: Perth, NOR Posted 09/08/07 08:37 AM Share Posted 09/08/07 08:37 AM (edited) Well I took it to a mechanic down the road from my work, we put it up on the hoist and he CANNOT undo the bolts. He tried so hard it was going to either snap the spanners or bend the fuel line somehow (yes we used 2 spanners going opposite directions...etc). I rekon its going to need the fuel rail replaced on either side of the filter back to the tank and up to close to the engine bay where theres a join in the line - cos its not coming off at all!Looks like im going to have to leave it to Ford to do when it goes in for whatever reason. I have the new filter in the box still, so there shouldn't be any problems with me handing them a new one and saying to fit it when its there next?? Its the proper one for the car by the way. Edited 09/08/07 08:39 AM by XF Falcon Link to comment https://www.fordxr6turbo.com/forum/topic/27295-replacing-fuel-filter/page/2/#findComment-562672 Share on other sites More sharing options...
