No Go
Featured Replies
#1
Here's a curly one for you :tease:
Drove my car home on Thursday night, no problems at all, parked it for the night, no problems.
Got out Friday morning, turned the key, and only a single splutter and then just cranking, but NO GO :spoton:
Have since spent a long time fault finding, and I have found that the trigger signal for the injectors is missing, so no fuel enters the engine :spoton:
I have checked everything, and it appears that all wiring is intact, all body (-) wires are present, and with low resistance (the injectors have constanty 12V on one side, and the PCM triggers the other side to body (-) as required to inject fuel).
Looks like the PCM may have died overnight Thursday to Friday :kissmy::tease:
  • Replies 52
  • Views 4.4k
#2
Are you getting a crank trigger signal?
#3
  • Author
I haven't specifically checked, but I would say so, as the ignition works, and if I rig a small siphon tube to suck some petrol under vacuum, the engine starts and runs.
Any other suggestions??
#4
Is the signal for the injectors feed straight from the ecm to the injectors..? what about the intertia cut out switch in the lh foot well? as far as i know it only shuts down the fuel pump but it may be worth checking..?
#5
fuel filter?? fuel pump? are you getting fuel to the rail? Pull a hose off and find out.
#6
How are you testing the signal to the injectors? I was lead to believe that the signal is very hard to measure with a normall digital multimeter so you have to use the plug in LED injector testers..?
#7
  • Author
It is definitely electrical, as Simon and I had the fuel pump out yesterday, and all confirmed OK.
I have also tried to connect a test lamp across the injector plug, and nothing happens, I.e. no earth, so the light does not come on when I crank the engine.
the 6 trigger wires for each injector comes directly from the PCM, and I have confirmed this connection is also physically OK.
#8
  • Author
You may be right, but I do not have one of these :spoton:
#9
do you have a mulitimeter that can test duty cycle and frequency.?
#10
If you dont have an injector testor you would need a light source that draws the same current as the injector to test for a signal..
Recently Browsing 0
