Trough Lolly Member 4,349 Member For: 20y 9m 17d Gender: Male Location: Mildura Posted 22/07/06 01:31 AM Share Posted 22/07/06 01:31 AM Nipro make one injector now its called a 100, They are big enough to support over 450 rwkw's, Very easy to tune with and are cheap, 600 exchange.←for 600 one may aswell buy the bosch 968's and then they still have the stock injectors to put back in when they sell the car down the track. a $600 drill bit would want to be a beautiful thing.... Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410313 Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 4m 17d Gender: Male Location: Perth Posted 22/07/06 01:46 AM Share Posted 22/07/06 01:46 AM Nipro make one injector now its called a 100, They are big enough to support over 450 rwkw's, Very easy to tune with and are cheap, 600 exchange.←for 600 one may aswell buy the bosch 968's and then they still have the stock injectors to put back in when they sell the car down the track. a $600 drill bit would want to be a beautiful thing.... ←968's wont support big power. Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410339 Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 8m 24d Gender: Male Location: Melbourne, Victoria Posted 22/07/06 03:34 AM Share Posted 22/07/06 03:34 AM QUOTE(Xtreme F6 @ Jul 22 2006, 11:01 AM)Nipro make one injector now its called a 100, They are big enough to support over 450 rwkw's, Very easy to tune with and are cheap, 600 exchange.for 600 one may aswell buy the bosch 968's and then they still have the stock injectors to put back in when they sell the car down the track. a $600 drill bit would want to be a beautiful thing.... I have a set of Nizpro 110s in my car and the injectors are well within capability at 440 rwkW. The 110s are the biggest Nizpro did it at the time.In the earlier days, they used Nizpro 60s (I think) but they ran out of flow around 340-350 rwkW. To give you some idea the 110s are about 910 cc/min, the 968s are about 440 cc/min and won't be able to support over 350 rwkW and have sufficient headroom (aka safety).Also wrt drilling the injector, it's not done by Nizpro themselves. A specialist modifies the injector using a precision drilling technique and then checks the injectors for flow match (across the set of 6) and the spray pattern. Sure atomisation will be effected, but when you after big numbers you can't expect not to sacrifice some economy and emissions.CheersRobin. Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410379 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m 4d Posted 22/07/06 08:39 AM Share Posted 22/07/06 08:39 AM (edited) but when you after big numbers you can't expect not to sacrifice some economy and emissions.←lets just hope EPA vicotria dont read this forum Edited 22/07/06 08:41 AM by Fat-Tony Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410499 Share on other sites More sharing options...
xrboss8 Member 156 Member For: 19y 11m 27d Gender: Male Location: Adelaide Posted 22/07/06 09:11 AM Share Posted 22/07/06 09:11 AM Nipro make one injector now its called a 100, They are big enough to support over 450 rwkw's, Very easy to tune with and are cheap, 600 exchange.←what is the flow rate of these? Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410507 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 30d Gender: Male Location: Victoria Posted 22/07/06 09:12 AM Share Posted 22/07/06 09:12 AM I'm pretty sure they're 750cc. Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410510 Share on other sites More sharing options...
phildub Member 52 Member For: 18y 11m 9d Posted 22/07/06 09:23 AM Share Posted 22/07/06 09:23 AM These were the injectors Nizpro used when they passed the emmission test with a 400 rwkw stage three cobra kit. Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410517 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 26d Gender: Male Posted 22/07/06 02:21 PM Share Posted 22/07/06 02:21 PM You can get very fine drill bits that go up in very small increments from most larger hobby stores. I reckon this is all they use to drill the injectors in some sort of jig. Cant see any other way its done. Probably quite easy to do also. Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410620 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m 4d Posted 23/07/06 12:16 AM Share Posted 23/07/06 12:16 AM phildub when they did that emmisions test was, that wasnt to meet the tougher Euro3 standards which are now in place, but im sure simon would be on top of that in any case Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-410694 Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 19y 1m 26d Gender: Male Location: Hunter Valley Posted 27/08/06 10:00 AM Share Posted 27/08/06 10:00 AM """""Also wrt drilling the injector, it's not done by Nizpro themselves. A specialist modifies the injector using a precision drilling technique and then checks the injectors for flow match (across the set of 6) and the spray pattern. Sure atomisation will be effected, but when you after big numbers you can't expect not to sacrifice some economy and emissions.CheersRobin."""""""Lads, Would like to open up this topic again, as Ive just read the atomic website where they dont suggest using drilled out injectors.Whats your thoughts and who uses all Atomic gear they sell....ducks guts or what?cheersShock Link to comment https://www.fordxr6turbo.com/forum/topic/27060-nizpro-drilled-injectors/page/7/#findComment-427121 Share on other sites More sharing options...
