Dvd Software
Featured Replies
#1
I bought a computer which has a dvd burner but it fairly useless because most dvd,s I want to "backup" has copywrite protection ,ive been told to download a po\rogram called dvd shrink that removes this feature but for the life of me cant download it .....can someone help there has to be an easier way. :spoton:
#2
I have it Simmo, I might be able to send it to you.
#3
Try here champ:
DVD SHRINK
Go down to the bottom of the page and download the link that says "dvdshrink32setup.zip"
I use this and have no problems at all, but I run as little compression as possible, most of the time none whatsoever.
#4
Use the "re-author" option, select only the Title Movie, get rid of other languages and sub-titles....and you should get close to 100%.
#6
dvd shrink is far better option as I have used then all
#7
<{POST_SNAPBACK}>
Better than what?? other click and burn programs?? Curious..
The only advantage shrink and other like programs have is that they are quick.
#8
Disagree....DVD Shrink is not a "Click & Burn" Program.
It allows you to re-author, edit "features", choose options (such as languages, subtitles, and soundtracks ), & compress to useable size.
If you choose more than one "title" off the DVD, you can even be selctive on which titles to compress, or have sub-titles.
Not bad for a "click & burn" program.
( In fact....the one thing it DOESN'T do......is burn ).
#9
Yeah ive about 600 movies always used dvd shrink it works fine, but for a straight copy or if you want to burn on the fly if you have two burners you can burn from the movie straight to the blank disc, use a progam called 1click dvd in conjunction with dvd43 works great and can do a film in about 8 minutes depending on your setup cheers. :censored:
Dave
#10
I use clonedvd now - found it to burn superior to the others
Recently Browsing 0
