jEtONiT Legacy Donating Member 1,817 Member For: 22y 10m 15d Gender: Not Telling Location: next door.. Posted 28/06/05 07:11 AM Posted 28/06/05 07:11 AM looking to buy a factory lsd for a n/a xr6.. where can I get it done and what sould I expect to pay??longing for two-wheeled marks
maximum_velocity Lemming No #5 Member 1,991 Member For: 21y 9m 30d Gender: Male Location: Endeavour Hills, Victoria Posted 28/06/05 07:30 AM Posted 28/06/05 07:30 AM Why dont u just keep the single spinner and get an LSD conversion done at a diff specialist. Should only cost around $500
jEtONiT Legacy Donating Member 1,817 Member For: 22y 10m 15d Gender: Not Telling Location: next door.. Posted 28/06/05 07:49 AM Author Posted 28/06/05 07:49 AM Why dont u just keep the single spinner and get an LSD conversion done at a diff specialist. Should only cost around $500 could do that I guess. would there be much difference?I know a guy in a r31 who did a lsd conversion and his diff was always whining and finaly gave way.. back to single spinner. now hes got a lock diff.
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 4m 27d Gender: Male Location: Victoria Posted 28/06/05 07:54 AM Posted 28/06/05 07:54 AM That would make it exactly the same as the Ford one then!
maximum_velocity Lemming No #5 Member 1,991 Member For: 21y 9m 30d Gender: Male Location: Endeavour Hills, Victoria Posted 28/06/05 08:13 AM Posted 28/06/05 08:13 AM Why dont u just keep the single spinner and get an LSD conversion done at a diff specialist. Should only cost around $500 <{POST_SNAPBACK}>could do that I guess. would there be much difference?I know a guy in a r31 who did a lsd conversion and his diff was always whining and finaly gave way.. back to single spinner. now hes got a lock diff.<{POST_SNAPBACK}>If u get it done properly and done by joe schmo then it will work perfectly. If u dont like this idea get a welder and weld the bas*ard. Cheap and easy
YOOT Member 1,201 Member For: 23y 3m 3d Location: Birkdale Posted 28/06/05 08:50 AM Posted 28/06/05 08:50 AM That would make it exactly the same as the Ford one then!<{POST_SNAPBACK}>So I'm not the only one with an LSD that behaves like a single spinner every now an then? Mainly when its cold.
CHIPS Great rack Legacy Donating Member 1,351 Member For: 23y 5m 27d Gender: Male Location: Geelong Vic. Posted 28/06/05 09:33 AM Posted 28/06/05 09:33 AM That would make it exactly the same as the Ford one then!So I'm not the only one with an LSD that behaves like a single spinner every now an then? Mainly when its cold.Mine's the opposite, it seems like its almost locked-up. Just lightly accelarating around a corner you can hear the inside wheel "skipping" and partially breaking traction. ...don't think it has ever spun just one wheel.
xr6t ute Member 442 Member For: 22y 5m 5d Gender: Male Location: Gold Coast Posted 28/06/05 09:42 AM Posted 28/06/05 09:42 AM Mines ok too, always 2 wheels Shane
jEtONiT Legacy Donating Member 1,817 Member For: 22y 10m 15d Gender: Not Telling Location: next door.. Posted 28/06/05 10:10 AM Author Posted 28/06/05 10:10 AM is it just me or should the lsd not skip while cornering.. shouldnt that make it a locked diff or a welded diff, 'coz that's how they behave..
YOOT Member 1,201 Member For: 23y 3m 3d Location: Birkdale Posted 29/06/05 04:55 AM Posted 29/06/05 04:55 AM is it just me or should the lsd not skip while cornering.. shouldnt that make it a locked diff or a welded diff, 'coz that's how they behave..<{POST_SNAPBACK}>Nah different mate, Lock diff will turn the inside wheel faster than it should and it will pull a the steering, the inside wheel will screech as you make the turn, and it might chatter if there is an uneven surface etc.The LSD will try to spin the wheel, but then be arrested by the LSD coupling and then try to spin again and the get arrested again etc... it will chatter as the cylce continues. WHen you completely overcook it the two wheels will almost lock and your spining both, usually sideways down the street!
