Maco_Turbo Member 6 Member For: 21y 5m 29d Posted 19/04/05 12:17 AM Posted 19/04/05 12:17 AM I purchased a K&N Air Filter yesterday (part no. KN332852) and it does not seem to fit perfectly.Has anyone else experienced this?Also which way do you put it in (Ie which side up?)Your views would be appreciated.Thanx
corpex Member 113 Member For: 21y 9m 17d Location: Melbourne Posted 19/04/05 12:29 AM Posted 19/04/05 12:29 AM It is much harder to secure the clamps around the box because it's rubber. I installed the filter with the grids facing downwards.
Dan K Member 40 Member For: 21y 10m 2d Gender: Male Location: Stanthorpe Qld Posted 19/04/05 07:23 AM Posted 19/04/05 07:23 AM the filter is not symetrical on edges all the way around. One corner has a different ( larger ) curve and this must go to the top right of the filter box. As you place filter in the air box the flat side faces up and the side with v shaped gauze goes down. Hope this helps.
Paradoxx Colossal Member Member 5,049 Member For: 22y 1m 15d Gender: Male Location: Perth, WA Posted 19/04/05 09:19 AM Posted 19/04/05 09:19 AM I had the same dramas with the BMC filter, the rubber is less forgiving than the stock filter so you will just need to put your back into it and clamp it on. Took me about 15 minutes farting around to get them on the first time. It does get easier after you have it in for a while.
cikas Team HgAg Member 616 Member For: 21y 11m 4d Location: Rockingham W.A Posted 19/04/05 09:41 AM Posted 19/04/05 09:41 AM Cheers for making the post Mac..I was in the market for a K+n myself... I know what to do know when the time comes...Now all I gotta do is try figure out how to do that 2nd CAI from the other posts..Doesnt hlp that I got NFI to do with T's..cikas
XtRmn8 570Nm @1800rpm Legacy Donating Member 2,441 Member For: 23y 18d Gender: Male Location: Perth, WA Posted 19/04/05 10:00 AM Posted 19/04/05 10:00 AM The filter can only go in one way due to the outer shape of the box. Mine went straight in with no problems. The clips can be hard to put back on but that's just haw they are, use a bit of force. 1 minute job!Good luck.
Swanga Benzene Member 432 Member For: 22y 4m 6d Gender: Male Location: Out West Posted 19/04/05 10:23 AM Posted 19/04/05 10:23 AM On the topic of filters, is there any difference in the k&n or the bmc???I know with the v8's the bmc is much better but what about the t's??
Paradoxx Colossal Member Member 5,049 Member For: 22y 1m 15d Gender: Male Location: Perth, WA Posted 19/04/05 10:38 AM Posted 19/04/05 10:38 AM BMC claim that it's better flow and higher performance, but I can't see any physical difference and the BMC I found was cheaper (and they didnt have any K&N in stock the day I went to buy one).
cikas Team HgAg Member 616 Member For: 21y 11m 4d Location: Rockingham W.A Posted 19/04/05 10:43 AM Posted 19/04/05 10:43 AM Whats the price on a K+n compared to a BMC??
XtRmn8 570Nm @1800rpm Legacy Donating Member 2,441 Member For: 23y 18d Gender: Male Location: Perth, WA Posted 19/04/05 01:41 PM Posted 19/04/05 01:41 PM My K&N cost me about $130. I bought it from SVO with another part plus payed postage and it still cost me less then buying the two parts here in WA!
