Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 9m 8d Gender: Male Location: Zombie Birdhouse Posted 12/04/05 09:45 AM Share Posted 12/04/05 09:45 AM xxxr6t,My car has a number of modification as like most people on the forum. My vehicle is two years old and ford have wiped the warranty on my driveline due to my modifications. I have no real problem with this.My problem eventuated since my fly by wire voltage fu##ed out. They fixed that problem but while they were there they decided to put the reflash in. And here we are today 62rwkws down.<{POST_SNAPBACK}>Beauies.... mate I have suffered power reduction as a consequence of a reflash 40rwkw I assume that because you know the drop in power that you had your T retuned. If not make sure you do ASAP as your AF ratios are more than likely all over the joint more than likely running as rich as buggery. Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-241744 Share on other sites More sharing options...
exar Member 187 Member For: 21y 2m 15d Posted 13/04/05 12:34 AM Share Posted 13/04/05 12:34 AM So again why should they do it to everyones car without giving notice<{POST_SNAPBACK}>I don't think they should do it without telling you (according to their own rules). In my case, it was mentioned when I called to book it in, and again, when I signed the form to get the work done (on the morning I dropped in into the service depot).Did you sign a form? Any work - such as the reflash, should have been on it. Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-241950 Share on other sites More sharing options...
BLK6T Member 305 Member For: 20y 7m 12d Gender: Male Location: Sydney NSW Posted 13/04/05 12:47 AM Share Posted 13/04/05 12:47 AM I questioned Ford about this and they have taken it seriously, apparently there is a guy called Tony from Ford who is contacting me soon to investigate further. I say we all rally together and put a stop to this. But what surprised me was how quickly Ford reacted when I questioned them about it. It would make my case stronger if some of you contact Ford also... Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-241959 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 9m 3d Gender: Male Location: Perth, WA Posted 13/04/05 05:44 AM Share Posted 13/04/05 05:44 AM Ahhhh I see where the problem is now, sorry I was under the assumption your ecu hadnt been tuned. Basically what has happened is they have over-written your current tune (I assume you are using something like a CAPA flasher or similar?) and basically returned it to stock. You are exactly right about them not doing the right thing, but as far as they were concerned your car is stock and the ECU hasnt been touched. If you have lost your tune/maps due to their re-flash then you have every right to jump up and down, especially if you paid for the dyno time to get it to where you want it. If they re-flashed it without consulting you then their liability depends on a couple of things, did you inform them that the ECU has been custom tuned? If so then they should be liable for the cost of getting it back to the standard it was before they changed it. If not, then they were pretty much doing their jobs as directed by the Ford Recall of those models.I dont suppose you have saved your edit somewhere? (do you still have it on the flash tuner?) Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242009 Share on other sites More sharing options...
Grass Donating Members 447 Member For: 21y 3m 10d Gender: Male Location: Sydney Posted 13/04/05 07:09 AM Share Posted 13/04/05 07:09 AM I questioned Ford about this and they have taken it seriously, apparently there is a guy called Tony from Ford who is contacting me soon to investigate further. I say we all rally together and put a stop to this. But what surprised me was how quickly Ford reacted when I questioned them about it. It would make my case stronger if some of you contact Ford also...I have and am also awaiting a call from Tony..... Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242041 Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 5m 11d Gender: Male Location: Gold Coast Posted 13/04/05 08:40 AM Share Posted 13/04/05 08:40 AM Whats the problem.If you have Flashed your car with the CAPA Edit, and Ford overwrote it, then just flash it back again. If you have a piggyback however, its a retune from your piggyback dealer for you One distinct advantage of the Edit , until Ford go to flash it again someday, and see its not the version they flashed in last time , and then ask rude questions You cant win, oh well, its how you play the game that counts Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242079 Share on other sites More sharing options...
beauies Member 209 Member For: 21y 8m 5d Gender: Male Location: sydney Posted 13/04/05 12:14 PM Share Posted 13/04/05 12:14 PM My after market tune is through a piggyback computer which was out of the at time of fords reflash. Another car from the same place I have my car tuned at had left his aftermarket computer in.Both cars after the reflash ended up with the same problem lack of kws.XXXR6T you are right as a couple of others are once this reflash is applied to the car it is running air fuels of 10.8My car was on the dyno again this arvo for another 1.5 hours still no result in finding kws.If anyone knows about the TSI piggyback, we have even played with clamping voltages with no result.Nothing seems to be working.We are not looking in the right spot for the answer.So any ideas anybody? Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242168 Share on other sites More sharing options...
Guest journo Guests Posted 14/04/05 02:28 AM Share Posted 14/04/05 02:28 AM HELP. I'm a journalist working for the Sunday Tele and doing a story about this XR6 overboosting recall. I've found a couple of people who have suffered it but I need a few more to speak to.I'd also really like to hear from someone based in Sydney who could be in a photograph with their car for us.If you can help please email at corbys@newsltd.com.auThanks. Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242319 Share on other sites More sharing options...
BLK6T Member 305 Member For: 20y 7m 12d Gender: Male Location: Sydney NSW Posted 14/04/05 11:38 PM Share Posted 14/04/05 11:38 PM I questioned Ford about this and they have taken it seriously, apparently there is a guy called Tony from Ford who is contacting me soon to investigate further. I say we all rally together and put a stop to this. But what surprised me was how quickly Ford reacted when I questioned them about it. It would make my case stronger if some of you contact Ford also...<{POST_SNAPBACK}>I have and am also awaiting a call from Tony.....<{POST_SNAPBACK}>You must have got the same reply as me then. Its funny how they have not replied YET!!! Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242560 Share on other sites More sharing options...
Grass Donating Members 447 Member For: 21y 3m 10d Gender: Male Location: Sydney Posted 14/04/05 11:47 PM Share Posted 14/04/05 11:47 PM HELP. I'm a journalist working for the Sunday Tele and doing a story about this XR6 overboosting recall. I've found a couple of people who have suffered it but I need a few more to speak to.I'd also really like to hear from someone based in Sydney who could be in a photograph with their car for us.If you can help please email at corbys@newsltd.com.auThanks.What recall ?Ford have not contacted me about it, I have not seen anything in the papers etc....Has anyone had information from Ford about a recall ? Link to comment https://www.fordxr6turbo.com/forum/topic/16714-wheres-the-power-gone/page/6/#findComment-242562 Share on other sites More sharing options...
