  • Member For: 23y 11m 8d
Posted
I'd seriously consider another T at the end of my lease if a 6 speed auto was available. Won't get my hopes up though - wouldn't surprise me to see it just in the FPV range (maybe a nice way to get the F6 back on track).
  • Replies 72
  • Legacy Donating Member
  • Member For: 23y 11m 29d
Posted
There are versions rated to 650nm, so they are pretty strong, alot stronger than the 4 speed BTR. Its a close ratio box so a higher diff ratio will probably be used, probably around a 2.8 ratio.
<{POST_SNAPBACK}>
First is waaay low for an auto at around 3.5. At least this is what I've heard????? Where's harasn when we need him?
<{POST_SNAPBACK}>
In my dreams Jeff, a 3.5 1st would be awesome for us that want to run the car down the 1/4, would allow the car to get "on top" of the tyres very early.
Scotty
<{POST_SNAPBACK}>
Yep, and on the strip is probably about the only time you'll see first gear used.
As I understand it the box is programmed to start in second gear during "normal" driving and will only kick back to first if the throttle is mashed through about 25% or more of it's travel within 0.25 secs or some such parameters ... or if an extreme load is sensed at the torque convertor as in steep hill starts or towing heavy loads. So loading up the stall speed at the drag strip will see you getting a first gear start easy eh?
  • FORD FORD FORD
  • Member For: 23y 6m 22d
Posted
It will with my Pineapple edit program & SSSSSS adaption
Scotty
  • When in doubt ... Accelerate!
  • Member For: 23y 1m 1d
Posted
still auto though :thumbsup:
I cant do it .... I knows its faster but I cant ....
Ive heard something about a 7 speed merc ....
isnt it getting a little outta hand ... soon its going to be like a truck 13 gearer :lol: :lol:
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 23y 6m 24d
Posted
Your info sounds very impressive but I cant see why ford would put a 6 speed auto in the falcon and not just a 5 speed auto. 6 speed auto sounds rare and very expensive. They would get the same marketing and popularity result out of a 5 speed auto. Really a 6 speed auto sounds to good to be true, but I do look forward to seeing it. I think such a box would be made available on the 2007 falcon, a bit early for MkIII.
Remember the good old days when Pontiac had a 4 speed auto but only ever used the 2 speed, becuae if you're not going to shift it, why worry how many gears it had!
Just needed one to get to cruise speed and another to sit on cruise....
Guest dc_todd
  • Guests
Posted (edited)
the reason they can do it is Jaguar already has a 6 speed box that they have been using in their xj40 and xkr-r simple inventory share, I think its just a different bellhousing and shorter tailshaft, the BA ECU just gets a shift pattern reprogram, that being said its probably easier than it sounds, as previously suggested it could prove to be expensive, but depending where they are made, there is rumour from Jag they are looking to go into mass production on the boxes and are looking for a factory, I just pray that BTR don't get it, I can't see the same quality coming from them as Jags current supplier.
The boxes as fitted to the Jags are tiptronic boxes, but I can only see it being put in top line models initialy, ie, FPV fairlane and possidlby xr8 and xr6t's.
rant over
sorry everything in the current jag lineup offers this box with the current xkr-r pushing 553Nm through it.
Edited by dc_todd
  • Member For: 21y 10m 14d
Posted (edited)
They wouldn't dare take away SSS with the new 6 speed, would they - ie just leave it as a 'normal' auto?
Edited by wiresquire
  • FORD FORD FORD
Posted
It (SSS) has been a massive portion of their marketing stratergy for the BA line up.
Scotty
  • Member For: 22y 2m 4d
Posted
has anybody heard anything about the v8s for copperhead or will they just bend over and continue to get taken by hsv or even Expensive Daewoo :blink:
Posted
rant over
<{POST_SNAPBACK}>
Ford's access to the ZF is not only via Jaguar. Ford USA are also using it in the Lincoln Navigator. It is also in Land Rovers. Rolls Royce and BMW also have them.
I'm told the BMW X5 box is pretty much the version we'll be getting. Unfortunately it is the only one I can't find ratios for. The ZF 5 -speed ratios are:
3.42, 2.22, 1.6, 1.0, 0.75. I think the 6 speed has the same first, fourth (becoming fifth) and top with an extra cog slotted in between the other three intermediates.
However, if they go with the Jag/Navigator box we'll possibly see ratios like this:
4.17, 2.34, 1.52, 1.14, 0.87, 0.69. Yes, that's right a first gear of 4.17!!! And no direct driven gear anywhere!.
