XRSICKT Member 1,032 Member For: 23y 5m 26d Gender: Male Location: Sydney Posted 14/12/04 10:03 PM Author Posted 14/12/04 10:03 PM *TIP*If your home PC or office worstation needs to be on 24/7, give it a restart once a day to prevent crashes, loss of data and overall problems.
Grant Member 453 Member For: 23y 10m 9d Location: Kurrajong, Sydney Posted 15/12/04 10:58 PM Posted 15/12/04 10:58 PM Ok, slightly more technical one for you guys....2003 Server distributing DHCP to clients. A new default gateway is introduced to the DHCP settings (scope options not server options). The old default gateway is pushed down to be the secondary gateway.All clients receive the settings but after five minutes, checking via ipconfig reveals that the clients have lost the setting of the new default gateway, and have reverted back to the old default gateway (now the secondary). Rebooting just replicates the problem, while a release/renew just starts the cycle again. Setting there, then not there.There is only one DHCP server in the network.Any ideas?Background info... the office is in an area where adsl is not available, so we have satellite. This is very expensive. We are trialling unwired but because the signal is not that strong (reliable) we need all VPN traffic to run through the satellite, while all other traffic runs out of the unwired - hence the new default gateway. Any thoughts?Grant
XRSICKT Member 1,032 Member For: 23y 5m 26d Gender: Male Location: Sydney Posted 16/12/04 12:14 AM Author Posted 16/12/04 12:14 AM Sounds to me like there may be something else on your network giving out DHCP settings, could that be a possibilty?
Grant Member 453 Member For: 23y 10m 9d Location: Kurrajong, Sydney Posted 16/12/04 12:19 AM Posted 16/12/04 12:19 AM Officially there's only the one dhcp server, but I decided to sniff the network anyway. Didn't find anything though.Very strange and very frustrating...Grant
jdo Member 88 Member For: 22y 3m 11d Location: Mosman Posted 16/12/04 02:26 AM Posted 16/12/04 02:26 AM Are there maybe any login scripts (run from AD) that are running a batch file or command to modify your gateways using the 'route' command?Just a guess, if you're sure there are no other dhcp offerers around. I know it's a bugger unplugging the dhcp server (which probably does other more important things as well) but you'll have to have done that (and I assume you have.)
XRSICKT Member 1,032 Member For: 23y 5m 26d Gender: Male Location: Sydney Posted 22/11/05 09:49 AM Author Posted 22/11/05 09:49 AM hey all, anyone know where I can get a free program I can run that will tell me the computer's serial number?
ZAP No boost, no bottle, just my foot on the throttle! Legacy Donating Member 7,935 Member For: 22y 7m 27d Gender: Male Location: Sydney Posted 22/11/05 10:05 AM Posted 22/11/05 10:05 AM The only serial number is in the CPU, is that what you are after ?
XRSICKT Member 1,032 Member For: 23y 5m 26d Gender: Male Location: Sydney Posted 22/11/05 10:14 AM Author Posted 22/11/05 10:14 AM I dunno, if that's the only one then it must be what I'm after.
XR64T Are we there yet? Legacy Donating Member 703 Member For: 23y 10d Gender: Male Location: Sydney, NSW Posted 22/11/05 01:12 PM Posted 22/11/05 01:12 PM Ok, slightly more technical one for you guys....2003 Server distributing DHCP to clients. A new default gateway is introduced to the DHCP settings (scope options not server options). The old default gateway is pushed down to be the secondary gateway.All clients receive the settings but after five minutes, checking via ipconfig reveals that the clients have lost the setting of the new default gateway, and have reverted back to the old default gateway (now the secondary). Rebooting just replicates the problem, while a release/renew just starts the cycle again. Setting there, then not there.There is only one DHCP server in the network.Any ideas?Background info... the office is in an area where adsl is not available, so we have satellite. This is very expensive. We are trialling unwired but because the signal is not that strong (reliable) we need all VPN traffic to run through the satellite, while all other traffic runs out of the unwired - hence the new default gateway. Any thoughts?GrantTry:ipconfig /allIt will tell you the IP address of the DHCP that you received your IP address from.How are you doing two "default" gateways? Obviously two defaults are impossible for the computer to understand. Are you defining routes for different Internet addresses via each gateway using the route commands?Can you main gateway router handle the re-direct for your clients? What I mean is, have one router as the gateway for all clients and have it know which way to route the traffic.??Cheers,Azz
XRSICKT Member 1,032 Member For: 23y 5m 26d Gender: Male Location: Sydney Posted 13/06/07 10:01 AM Author Posted 13/06/07 10:01 AM Why won't some PCs with winXPSP2 and good wireless network cards allow you to connect to the wireless router with 128bit encryption yet will have no problem with 64bit encryption. When comparing a working PC's settings to one that won't work I see no difference.
