useless Member 259 Member For: 22y 3m 26d Gender: Male Posted 11/06/04 11:59 AM Posted 11/06/04 11:59 AM PS YOU CAN GET EARTH SHIELDED RCA CABLE ALSO TO ELIMINATE INTERFERENCE INTO BASIC RCA CABLES
Blown BA In Your Face Member 6,195 Member For: 23y 6m 20d Gender: Male Location: Peninsula Posted 12/06/04 12:12 AM Posted 12/06/04 12:12 AM :lol: I had this whine through the Aux input : Did you fix the whine CSNAKE, cause l sometimes get that too.
cutsnake Member 122 Member For: 22y 10m 29d Posted 12/06/04 07:11 AM Posted 12/06/04 07:11 AM Did you fix the whine CSNAKE, cause l sometimes get that too. I haven't bothered yet..Will get to it in-time. May have to relocate the leads or use cabling with better sheilding?
Blown BA In Your Face Member 6,195 Member For: 23y 6m 20d Gender: Male Location: Peninsula Posted 13/06/04 01:00 AM Posted 13/06/04 01:00 AM Did you fix the whine CSNAKE, cause l sometimes get that too.I haven't bothered yet..Will get to it in-time. May have to relocate the leads or use cabling with better sheilding? I remember using some sort of sheilding for the wires yrs ago, it was aluminium made in some type of duct tape...is that the one?
HI PSI Member 1,589 Member For: 20y 4m 4d Gender: Male Location: Central Queensland Posted 04/08/06 01:29 PM Posted 04/08/06 01:29 PM I did custom car audio installations for 5 years. 90% of all engine noise is due to poor earthing. Another cause is running a high voltage power lead/source beside your RCA leads. This is why good installers run all power supplies for amplifier down the right hand side of the car and RCA's down the left. This is done so you keep you signal as far away as possible from any power sources eg:- brake, blinker wires. Simply run your earth under the bottom of the rear seat. Drill a 1/8 hole, sand away paint ant scew down earth. Paint over when attached. Another cause is difference is potential (resistance) in the earth when running multiple amplifiers. To rectify this just earth all amps at the same point. Is is also good practice to uprage the earth from the battery to the chassis. Good luck guys. hope that this helps
