Everything posted by NATHOON
Wsid 11/7/07
12.2 118 mph the 6 speed auto is giving me some issues it sucks all the boost out when it launches
Attention All Walbro Pump Users
Try an external and you will say she is as quiet as a mouse
Tool Box In Tub Liner
I have two utes with tool boxes and I screw it down to the steel sections using the bolts that hold the old factory tie downs with.( they both have trade racks) they do not move an inch. Pilot drill the holes then screw. Make sure you set the depth of the drill.
Engine Breaking/cutting Power..
Drop the exhaust undo the diff undo the tail shaft slide the diff back and slide the tank out 2 hou job with a hoist
Malwood Option 3 Clutch Group Buy... Edit: still window shopping no confirms...
Ill back it mine cops hell and is still going strong
044 And Swirl Pot
Dont forget its cool at the moment wait till temps start to rise summer all you will hear is buzzzzzzzzzzz buzzz buzzzzzzzzzzzzzzzzzzzzz the fully rubber mounts allow the pump to vibrate without transferring the vibration to the car
044 And Swirl Pot
The only way to make that pump bareable is to use the proper mounting bracket $50 and mount it on the rubber lugs that you pull off the factory cooler. I tried everything and that was the only way. once the pump and fuel gets hot it will get louder. Mine was really good I mounted it under the tray on top of the diff away from it of coarse
Victorian Tuners
Dont let stooges tell you what to do go and see a few. You have a few quality tuners down that way.
Tow Rating Xr6t Question
Mate I have the hayme and reese tow bar on my f6 tornado. I got this put on so I did nt have to cut the lower pannel out (its removable). It is rated at 2400 kgs this is the tow bar you need Nathan
Power Happy Median
They fixed that in the bf
Progress Update: How Is BCL's Car Going?
I have just been through this too and even though I was paying by the month you still have to pay the poliicy out (12 mths) when you claim with whatever excess if any
Bf Mkii Typhoon Fog Light Inserts
I am thinking prior to replacement a bit of silcon or clue behind just to hold the suckers in. I had a typhoon loan car whilst mine was in for 3000 km service drove back to ford and on there driveway the insert poped out so easy I am going to silicon mine in from behind
Awsome clutch make sure you guys opt for the external bleed block and the 11 inch alloy flywheel option. The bleed block is esential otherwise you will have all sorts of trouble with bleeding the box correctly. Mine is still going strong 15000 kms @ 355 rwkw and my ute is loaded for work
T5 Still Alive!
you have just jinxed yourself cannot wait for your next thread
Et Streets
Or what other tires should I run to hook up
Et Streets
What size et street will I fit under the arse of a ute.. I have a set of ba territory rims they are stamped 17 x 7.5 will they fit the 275/40 r17 streets?. alternatively I have some chaser 16's of a ba wagon will they clear the brakes on a f6 ute?
Process West Plenum/cooler Kit Fitted :)
I have a feeling more zf than rods but time will tell if it brakes then you just have to build one stronger
I want 400+ rwkw on this ute my last one had 343 with standard airbox stage 2 process west standard plenum and the list bellow the new 1 gets Full plenum kit process west & Siemans injectors 4inch dump 5 inch cat twin 2/1/2 inch out the back Wastgate and actuator Crow valve springs Fuel Pump Edit
fitted mine today ready for a tune next thursday I know what you mean about induction cant wait till 18 psi gets thrown in then it really will live up to the tornado name
Clutch Problems
Their clutch blew apart how is that your fault? How long did you drive with it making a noise usually it will only make 1 hole?
Business Cards
www.clickbusinesscards.com I use these guys do it on the net load your graphics pay and deliverd to your door in 2 days. Cheap too Nathan
Exhaust Options
Do not remove the centre muffler from a ute it sounds sh#t house. I have noticed under my new fpv tornado fpv has changed the rear muffler and sounds a bit meatier than my bf ute that was written off
New Tuning Option
So do you guys offer this service if so how much? Nathan
Personalised Plates
Just ordered trn880 for my new tornado
Weird Squealing - Howling Noise Under Boost
Make sure the new pipe from the right side of the cooler that comes up past the airconditioner is not touching the a/c when you hit the loud pedal. Check the clearence because it is tight
