Everything posted by stretch4660
Mamba fasteners
Hey gents Quick question: The Mamba fasteners you see on fleebay (eBay), are they legit/what they are portrayed to be.? I want to change my manifold bolts out to studs and nuts
Exhaust Change - Re-tune Required?
Yep I can confirm after fitment of the hi-flow cat, it runs fine without a tune, can even give it a little more throttle than I first thought I’d be able to, she’ll be fine until it’s tuned
Fantastic, thank you sir
So can I fit my venom 3 inch turbo back with hi-flow cat and baby the car around for a few weeks before I go get it tuned, I’ll be buggered if I’m paying someone else $200 to fit it when I can do it myself no worries for free.? ? Basically can I drive with hi-flow cat without a retune, but take it easy or not.?
FG n/a motor to BA turbo conversion
First thing, reliable + power = not cheap.! Secondly, who f*ckn knows what the tuna will do with the cam timing, so that question doesn’t really matter. (It depends on so many factors) Thirdly, all that stuff you wanna do sounds like about $5k minimum worth of parts/work/labour, is it really worth it.? There are some dirt cheap turbo falcons for sale at the moment, would it be better getting one of those.?
Possible overboost problem (BA)?
Vacuum leaks are easy to find, use something flammable, eh, ‘brake cleaner’ or ‘start ya bastard’ engine should rev up slightly/ping if a leak is present when you spray the vacuum lines.
Recommend a garage jack
Quality is not cheep, crudd is not expensive, can be a tough call, I think mine was about $275, has lasted 5 years with no drama until recently, oil seal is leaking now, probably be cheaper to replace the whole jack than repair the cylinder and seal.
Balancer puller
Nice..! thank you kindly.
Balancer puller
Best place to purchase a balancer puller for a Barra turbo motor?? preferably online. Thanks
- Brake Shudder - On The Hunt For The Problem. Over Heated Brake Fluid?
Rebuild or part out. That is the question....
Do you want the $$ or do you want the car.? The answer pretty much determines what to do with the car mate.
Can feel corrosion break away inside when squeezing coolant hoses
Replace the hoses man, plain and simple, more likely the rubber in the hose breaking down and becoming brittle, as you squeeze it, it cracks, that'll be what you're feeling, seen it 100 times before in all makes and models of car.
Am I missing something?
Hey, sorry guys, yeah worked a treat, ended up using terminal 5, compression varied slightly from 180psi in cylinder 1 and 2, and 175 for 3, 4, 5 and 6, so yeah not to bad for an engine with over 265,000km on her :D
Thank you for your assistance and your awesome knowledge kind sir.
legend, thanks heaps. Last question I promise, which number do I bridge from the relay to the battery sorry? 2,3,4 or 5?
Trying to do a compression test on my 09 fg xr6t, got her all apart, coild and plugs out, gauge hooked up ready to go, turn the key and nothing happens, just a click of a relay (assuming starter relay? and no, there is nothing wrong with the relay) What am I missing? Something to do with that auto start crap.? How you flick the key and it'll crank the engine for you till it starts.? little help would be awesome please ??
Faith restored
Well after month and month and many many km's since the issue first began, finally replaced my ignition coils as one was breaking down under moderate load, anything over half throttle she'd piss and fart about, spark breaking down and carrying on went for a quick thrash with new plugs and could and god damn I'd forgotten how quick these cars are, it's been so long since I've been able to full throttle the engine, couldn't get anything above about 8/10 psi, now she sings to her full potential again of 15psi ???? Can't wait to thrash it again tomorrow on the way to work
Front seal oil leak
Yeah the float doesn't feel to bad, when cold anyway, haven't felt it when warm, she'd tighten up marginally I'd assume, that's how I like em anyway, tight and warm ???
Front seal oil leak
need to justify this stuff to the chief financial officer first hahaha
Front seal oil leak
Any ideas on the marks on the impellor wheel? I'm guessing particles hitting it at high speed, 260,000km+ on the car/turbo, probably due for a birthday
Front seal oil leak
Found the impellor housing had some oil laying in it this afternoon, looks like I'm up for a new seal/bearings, any ideas of the best place to get a turbo rebuild kit for a stock 2009 fg ute turbo.?
Had a bingle.!
Haha 'local wrecker' is 300km away. Yeah I figured they wouldn't bloody miss ya hey. Guess I'll start trawling internet pages in search of a good deal. Thanks mate
Had a bingle.!
Backed into a fukcin pole this arvo.! Anyone got an idea of what an FG turbo ute tailgate and rear bumper are worth from Ford.?
Oil/Filter Change
No need to get under the car at all, that sh*ts for amatures. Take the airbox and intake pipe off to where it joins the pipe over the engine (FG), once airbox is removed the oil filter is right there and you can reach the sump plug by reaching down the side of the engine and over the K-frame. 15mm spanner = happy days, job done, no rolling on the floor for me ??
High-Kilometre XR6 Turbos: How Many km Have You Clocked Up?
Cracked 240,000km the other day, well on the way to the quarter tonne.! Gave her a birthday with a nice oil change, thrashed daily and still loves it ??
