  • Member For: 18y 10m 26d
Posted
I just got back from a drive in my BA T (about 200km's) and not far from getting back home I noticed a ticking noise coming from the engine.
The ticking rises and falls with the revs and started out quiet but got louder. I turned the car off when I got it in the garage and popped the bonnet. couldnt see any oil or anything wrong. went to start it back up but it wouldnt start, it was like the engine had locked up. so I left it for a a while and then went back and it started normally but still had the ticking.
I had a bit of a listen around the engine and it sounds like its comming from the top somewhere but I cant be too sure.
Just wondering if anyone would know what the problem is or got any ideas where to look?
Details: 03 BA XR6T Nizpro injectors, valve springs, tune, cooler, intake, turbo modded.
  • Replies 47
  • Member For: 19y 5m 3d
Posted (edited)
I hate to be the bearer of bad news but im guessing you have a bent rod on your hands
although I hope for your sake im wrong I wouldnt be driving it untill somebody has a good look at it because the next step is it smashing a hole in your block and coming out for look of the inside of your engine bay shutup.gif
cheers trev
Edited by trevs
  • My new toy
  • Legacy Donating Member
  • Member For: 23y 5m 2d
Posted
I would say very good chance of that.
Ian
Posted
I let it sit for a few hours then started it and theres no ticking for a bit then it slowly comes back.
I dont know whats wrong with it :beerchug:
Posted
the fact your engine locked up still makes me think bent rod
as the oil warms up or thins out the ticking comes back bent rod
ticking sound that increase with rpm or under load bent rod worse case scenario anyway
id stop starting it untill somebody looks at it better to be safe than sorry a bent rod may not be the end of the world a hole in your block is major pain in the ass
anyway like I said I hope for your sake its something simple and cheap but the fact I see your cars pushing 340rwkw I dont hold much hope
cheers trev
Posted
Im going to give my tuner a call in the morning and see what he says. If he needs it in there I'll get it towed in so they have a look at it.
It sounds like its in the valve train somewhere like a rocker or something.
it reminds me of my old skyline with the RB30 and the usual ticking that those things develop, oh the memories haha
Posted
yep its sure does suck
If it's Got Tits or Tires, Sooner or Later You are Gonna Have Trouble
cheers trev
  • Member For: 20y 9m 29d
Posted
I know this sound very well, I have the same sound coming from my engine. Mines a BA standard valve springs, I was wondering what the chances are of having a bent valve rather than a bent rod, could the bent valve be stuck open with the piston tapping it every cycle? I guess im going to comp test it and see if its top or bottom, Im over the guessing game.
  • Member For: 18y 3m 10d
Posted
Check out my thread...
http://www.fordxr6turbo.com/forum/index.php?showtopic=64317&st=0&p=962825&hl=knocking+from+motor&fromsearch=1
If it sounds anything like this DONT drive it anywhere. I had 2 bent rods, #3 was bent on both axis and was bent that bad that the rod was hitting BOTH sides of the cylinder causing a small crack in the block. The actual knock you can hear in my vid is the piston hitting on the crank (the cylinder bore had a groove worn in it from the rod and wasn't touching), I bent the rod that much that on the down stroke the bottom of the piston would hit on the top of the crank... it cost me $3000ish for a new FG F6 short motor. I'd trailer it to you tuner and let him have a look at it, and I'd highly recommend a compression test. Best of luck. :bowdown::buttrock:
