Dannopower Legacy Donating Member 421 Member For: 21y 3m 12d Gender: Male Location: Canberra ACT Posted 01/08/05 01:04 PM Posted 01/08/05 01:04 PM I need a trans cooler for my turbo, and was just wondering who has installed one in their 6T and what did they get?How much $ and do you think they are worth it?
Trough Lolly Member 4,349 Member For: 22y 9d Gender: Male Location: Mildura Posted 01/08/05 04:55 PM Posted 01/08/05 04:55 PM dont have one but used them in the past... Definately worth the money and worth doin if you plan to mod the T or do frequent towing,heavy work.shouldnt cost anymore than $250 for a FULL KIT including cooler,hose and clamps.can even fit yourself if you can twirl a spanner.
dingah2 Crusty aviator Member 846 Member For: 22y 2m 30d Gender: Male Location: ACT Posted 01/08/05 09:24 PM Posted 01/08/05 09:24 PM aaah Dunnopower.....call Pat & Jenny at you know where. Fitted mine at about $550 all up, a large core, large capacity Davies Craig and Penrite 10/10ths synthetic tranny fluid.Dingah
Dannopower Legacy Donating Member 421 Member For: 21y 3m 12d Gender: Male Location: Canberra ACT Posted 09/08/05 07:32 AM Author Posted 09/08/05 07:32 AM Ended up buying one from PWR. There a great looking little unit, and I have also been to Enzed and bought all the fancy fittings and braided hoses to hook it all up when it arrives!Whole lot including cooler, annodized screw on fittings (no crappy hose clamps!), and braided lines $340!Ill have to get some pics when its all done!
THEMESHMAN260 Member 155 Member For: 22y 8m 6d Posted 09/08/05 11:18 AM Posted 09/08/05 11:18 AM Ended up buying one from PWR. There a great looking little unit, and I have also been to Enzed and bought all the fancy fittings and braided hoses to hook it all up when it arrives!Whole lot including cooler, annodized screw on fittings (no crappy hose clamps!), and braided lines $340!Ill have to get some pics when its all done!<{POST_SNAPBACK}>Where do you mount the cooler on a auto
ms700 Moderating Team 10,170 Member For: 23y 7m 18d Gender: Male Location: Sydney Posted 09/08/05 11:23 AM Posted 09/08/05 11:23 AM Ended up buying one from PWR. There a great looking little unit, and I have also been to Enzed and bought all the fancy fittings and braided hoses to hook it all up when it arrives!Whole lot including cooler, annodized screw on fittings (no crappy hose clamps!), and braided lines $340!Ill have to get some pics when its all done!<{POST_SNAPBACK}>Make sure you use a oversize shifter when you tighten the anodised fittings, and not a spanner. The shifter's don't seem to mark the fittings near as much as a spanner does.....Just a tip. Maybe put some masking tape around the fittings to protect them some more.....
Dannopower Legacy Donating Member 421 Member For: 21y 3m 12d Gender: Male Location: Canberra ACT Posted 09/08/05 01:10 PM Author Posted 09/08/05 01:10 PM Meshman- It will mount in front of my radiator just above the intercooler.MS700- Thanks for the tip! hope to see you at dinner!
Dannopower Legacy Donating Member 421 Member For: 21y 3m 12d Gender: Male Location: Canberra ACT Posted 24/08/05 08:21 AM Author Posted 24/08/05 08:21 AM (edited) Here are some pics of my trans cooler mounted. Just waiting to get the braided lines made up, and connect it all up!Heres a before shot<div class='bbimg'></div>Had to make a new side mounting bracket to move the horn<div class='bbimg'></div>Fabricating the alloy brackets<div class='bbimg'></div>Lower bracket fitting<div class='bbimg'></div>All hoses and fittings are to be made up with braided lines(not shown) and screw fittings like these. Not a single hose clamp used, and I dont have to modify the current stock plumbing, except attach new fittings to them.<div class='bbimg'></div>All the brackets on the PWR cooler<div class='bbimg'></div>Fitting it in using an airline as a mock up to measure double check the lengths of the hoses<div class='bbimg'></div>And finally an after shot! (without the braided lines yet!)<div class='bbimg'>I have it angle mounted so if I choose to upgrade the intercooler down the track It will fit in, provided I dont go overboard with the size! And I can remove it and put it back to stock as none of the stock plumbing has been hacked into, shortened of removed. Just redirected!Now the transmission fluid is water cooled through the radiator, then air cooled by the new PWR cooler before heading back in for another thrashing!Hope you guys like!! Edited 24/08/05 08:24 AM by Dannopower
bjc Legacy Donating Member 2,823 Member For: 23y 14d Gender: Male Location: Townsville Posted 25/08/05 07:07 PM Posted 25/08/05 07:07 PM Would it have been better to just use the trans cooler instead of both radiator and cooler?Would your cooler be sufficient to cool the fluid on its own?And is there any problems with just using the cooler by its self?Thanks in advance,Brett.
GOLDIE My new toy Legacy Donating Member 5,344 Member For: 23y 4m 27d Gender: Male Location: stanthorpe wine capital of qld. Posted 25/08/05 07:39 PM Posted 25/08/05 07:39 PM Would it have been better to just use the trans cooler instead of both radiator and cooler?Would your cooler be sufficient to cool the fluid on its own?And is there any problems with just using the cooler by its self?Thanks in advance,Brett.<{POST_SNAPBACK}>No problem just using the cooler but I would use a bigger one if you did this.Ian
