Lerm New Member 13 Member For: 6y 6m 12d Posted 20/04/26 04:18 AM Posted 20/04/26 04:18 AM Recently had my fuel pump stop working and have pulled it out to realise its a Streetfighter 1000hp Fuel Pump Module. Am wondering what fuel pump I could put in the car that would be cheaper and not cause problems, car is currently at 440kw on 98 and 500kw on e85. Any advice would be greatly appreciated cheers.
k31th less WHY; more WOT Site Developer 30,100 Member For: 18y 5m 9d Gender: Male Location: Melbourne Posted 20/04/26 04:42 AM Posted 20/04/26 04:42 AM How expensive is the one that's in the "module" to replace it like-for-like? Also, what's your budget on fuel pumps?
xr6tForMe Legacy Donating Member 317 Member For: 13y 2m 21d Gender: Male Posted 20/04/26 07:16 AM Posted 20/04/26 07:16 AM 2 hours ago, k31th said: How expensive is the one that's in the "module" to replace it like-for-like? Replacing like for like seems like a good idea - you know that it will work at your power level.
Lerm New Member 13 Member For: 6y 6m 12d Posted 22/04/26 02:31 AM Author Posted 22/04/26 02:31 AM (edited) On 20/4/2026 at 2:42 PM, k31th said: How expensive is the one that's in the "module" to replace it like-for-like? Also, what's your budget on fuel pumps? The pump costs 1.9k, prefer not to spend over $1000 if possible. considering the wiring has been altered for this pump being a dual pump would I be able to put a stock fuel pump module with an upgraded single pump fitted? Or would it be alright to fit new pumps to the current street fighter module in the car? also if I was to put a stock xr6 turbo pump in from ford would I experience any issues (considering this as I’ve already got a stock pump in hand and need the car moving asap) Edited 22/04/26 02:33 AM by Lerm
k31th less WHY; more WOT Site Developer 30,100 Member For: 18y 5m 9d Gender: Male Location: Melbourne Posted 22/04/26 03:10 AM Posted 22/04/26 03:10 AM The entire "in-tank module" with two pumps is ~$1600 brand-new, so I'm not sure how your pump(s) could be $1900+... figure out which make/model (from the online listing: "2 x Bosch 300 lph pumps utilised") and find out how much just one is actually worth, or both if you need both. The stock pump would not keep up with the rest of your fuel system, not even close... would be extremely risky to run that setup even on small percentages of throttle use. Yes, you can fit new pumps to the current module.
xr6tForMe Legacy Donating Member 317 Member For: 13y 2m 21d Gender: Male Posted 22/04/26 11:33 PM Posted 22/04/26 11:33 PM 21 hours ago, Lerm said: Or would it be alright to fit new pumps to the current street fighter module in the car? I think fitting a new pump to the current module would likely be the best outcome and best value.
