Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 17/09/22 10:37 AM Share Posted 17/09/22 10:37 AM G'day, Recently had a set of raceworks 980 cc injectors installed ,venom high flow cat and a plaz 700 hp intercooler installed in my fgx turbo . Car went in for tune on fri all was good when I first drove the car , then engine light and codes via torque app with obd scanner. P0420 and P 1132 ,car idles rough as guts and now I've got bad rollover noise in the tr6060 . I don't know if I'm game to take it back to them ,isn't it standard to turn off the sensor after the cat when tuned . I got some lame dyno sheet with just the torque and hp . Nothing with afr or boost levels . It was closing time fri when I picked up the car so they were pretty keen to get my cash and get me out the door . On the torque app it's not overboosting ,do you think it's OK to drive or bite the bullet and go to a well known tuner on the nth side of brissy and get it retuned . Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,596 Member For: 17y 3m 4d Gender: Male Location: Melbourne Posted 17/09/22 10:38 AM Share Posted 17/09/22 10:38 AM Just take it back to the tuner... not worth your hassle to take it anywhere else... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714519 Share on other sites More sharing options...
Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 17/09/22 10:50 AM Author Share Posted 17/09/22 10:50 AM Thanks for being the part of my brain which isnt functioning properly ATM , I've corrupted my head with to much research and what ifs . It's a long time until Mon, no more reading into what it could be. I'll drop it back there Mon cheers Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714520 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,596 Member For: 17y 3m 4d Gender: Male Location: Melbourne Posted 17/09/22 10:53 AM Share Posted 17/09/22 10:53 AM no worries Just make sure you're clear with what you want from them, e.g. the dyno sheet with boost/afr & torque/power... and also an explanation for the codes and a solution that's in line with what you originally paid for - a tuned and normally running car. Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714521 Share on other sites More sharing options...
Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 17/09/22 11:02 AM Author Share Posted 17/09/22 11:02 AM Thanks mate ,much appreciated. Ive been lurking in the shadows on here for quite a while ,reading all the great info here . I usually just use the search but nothing really directly covered what I was looking for because only the tuner can answer it anything else I find is speculation which isnt good for an overthinker like me lol . thanks again Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714522 Share on other sites More sharing options...
Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 18/09/22 02:49 AM Author Share Posted 18/09/22 02:49 AM Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714526 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,596 Member For: 17y 3m 4d Gender: Male Location: Melbourne Posted 18/09/22 02:55 AM Share Posted 18/09/22 02:55 AM Torque and power drop off like a stone at ~140kph... not an ideal tune... Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714528 Share on other sites More sharing options...
Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 18/09/22 03:04 AM Author Share Posted 18/09/22 03:04 AM Yer I've seen a few other dyno sheets with the mods ive had done and a tune and mine don't look right the way it drops off .He said it was tuned to 12 psi but havent got that info yet . Will be asking the tuner tomorrow. Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714529 Share on other sites More sharing options...
Tom Tucker Donating Members 704 Member For: 6y 14d Posted 18/09/22 04:02 AM Share Posted 18/09/22 04:02 AM Looks pretty average man. Let us know how you go. Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714532 Share on other sites More sharing options...
Shagsalot Donating Members 16 Member For: 2y 10m 6d Posted 18/09/22 04:39 AM Author Share Posted 18/09/22 04:39 AM When you save,stash cash and plan for great and get average leaves you feeling a little disappointed. Lucky I've got my Mrs reminding me I should of just left it alone,like everything I just dont learn by mistakes, she's always right . Should sort it tomorrow with them ,they can't fix what they aren't aware of ,who frigging knows ,will let ya know what they have to say cheers Link to comment https://www.fordxr6turbo.com/forum/topic/96799-engine-light-and-fault-codes-after-tune/#findComment-1714533 Share on other sites More sharing options...
