Bionic Beast Donating Members 29 Member For: 4y 5m 4d Gender: Male Location: rAdelaide Posted 15/02/22 07:17 AM Share Posted 15/02/22 07:17 AM Im wanting to install one on my BF as it has the connector hanging there for it. I tried activating the light (before wasting money ob the sensor) but no matter what I did, crossing the pins, sending them 12v, grounding them ect I could not get it to show up. So was I doing something wrong? Was that plug not even for the sensor? (It definitely wasn't the 2nd motor plug) It was the ones that were plugged into each other. Or is it something ridiculous like the cluster has to be programmed for it or it doesn't even have the light? Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 4m 3d Gender: Male Location: Melbourne Posted 16/02/22 03:06 AM Share Posted 16/02/22 03:06 AM why do you need a sensor to tell you its empty? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,313 Member For: 16y 18d Gender: Male Location: Melbourne Posted 16/02/22 03:21 AM Share Posted 16/02/22 03:21 AM I didn't even know B-series XR's had a light for the "low wash indicator" on their instrument cluster... I suspect you'll need a specific cluster (perhaps fairmont... I don't know, just speculating) for that sort of light to show. Link to comment Share on other sites More sharing options...
Bionic Beast Donating Members 29 Member For: 4y 5m 4d Gender: Male Location: rAdelaide Posted 16/02/22 10:57 AM Author Share Posted 16/02/22 10:57 AM Yes you are right, I need a "high series" Cluster. The clusters that got paired with the colour screen ICC's. Since you loose the trip functions on the cluster to the ICC ford put door ajar diagram (shows you exactly what door is open), a PRND/ what gear you are in while tiptronic is engaged light and the washer bottle sensor. If you flick through your owners manual to the instrument section you can see the screens detailed better. I also found out if you remove the insert of your cup holder its made to hold milk drink cartons, finally somewhere to put my FUIC , whoever knew reading that manual was helpful That sucks for me since I've already gotten my "low series" Cluster modified and don't feel like paying again... Thanks for the tip off of different clusters though Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,313 Member For: 16y 18d Gender: Male Location: Melbourne Posted 16/02/22 11:02 AM Share Posted 16/02/22 11:02 AM well, it'll be a cheaper customisation to probably get the same guys to use one of your other lights for it; perhaps one you'll never use (for me that'd be the fog lights as I never use those things). Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,403 Member For: 14y 4m 3d Gender: Male Location: Melbourne Posted 17/02/22 01:41 AM Share Posted 17/02/22 01:41 AM (edited) seems like a waste of time to me, just make your car faster instead. Edited 17/02/22 01:41 AM by bossmang 1 Link to comment Share on other sites More sharing options...
Bionic Beast Donating Members 29 Member For: 4y 5m 4d Gender: Male Location: rAdelaide Posted 17/02/22 07:03 AM Author Share Posted 17/02/22 07:03 AM I've got an intercooler sprayer running from the tank, would be helpful to know when its empty so I''m not running the pump dry. Cant exactly see it while I''m driving can I? And what''s it to you what I do with my car. Idc if you think its a waste of time, I want it. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,135 Member For: 9y 2m 30d Gender: Male Location: South Australia Posted 17/02/22 07:27 AM Share Posted 17/02/22 07:27 AM (edited) If there is a low level switch in the tank it would be pretty easy run a relay setup and have a light come on in the cabin. If there is a symbol in the dash then there might be a light there. Even if there is no light you could put something there to make the symbol light up. Another option, don't bother with a relay and just run a lithium battery with led straight through the low level switch. No need to find power and frig around with a relay that way. Nek option is to find a dash to support it, a module file to support it, as well as the current modules, and flash the bastard to make it work like a factory setup. This way is the most legit way of doing it but I can't tell you if this option even exists. You'd have to do your homework and possibly use a bunch of trial and error to make it work. Another option, just check the oil, coolant, other fluids as well as the washer bottle once a week as you should anyway, then there is no need for a low level light. If you think you need an intercooler spray then perhaps consider a hectic intercooler upgrade. In my experience an intercooler spray does 2/3s of stuff all compared to a correctly sized intercooler. This is coming from countless dyno runs, and using a spray bottle on many an intercooler to get it cooled down after a long hot summer tuning session, just to get a hero run. Great for peak dyno numbers, not really that useful in a street car. Anyfreakinghow there's a few ideas to get it working, and maybe some ideas about upgrading and even needing it to start with. Edited 17/02/22 08:03 AM by Puffwagon Heh dyslexia Link to comment Share on other sites More sharing options...
