September 6, 20215 yr #1 Has anyone had a leaky sump, my fgx xr6t sump appears to have a leak in the bottom seam of the sump, it appears to have hairline cracks about the seam right up the front of the sump. I was thinking of getting it alloy welded by an engineer. Or would that be a bad move and destroy it? Could it be jb welded or anything? Thanks guys.
September 6, 20215 yr #3 4 hours ago, Slowxr6t said: my fgx xr6t sump appears to have a leak in the bottom seam of the sump, Clean it and confirm it. Edit: it's probably residual oil from your leaking turbo drain. Edited September 6, 20215 yr by Puffwagon Why not?
September 6, 20215 yr #4 Yeah any oil leaks tend to dribble down and collect there so definitely worth doing what Puff suggested to confirm
September 7, 20215 yr #5 Author After further inspection, I found it's a leaky crank pulley seal, I will replace it soon when I install new ATI balancer and atomic flexplate. I've ordered a genuine ford seal. Any tips for a successful no leak seal and pulley install??
September 7, 20215 yr #6 You'll need a small gear puller and dont forget to put some sealant on the back of the crank bolt washer.
