FG2XR6T New Member 7 Member For: 3y 9m 27d Posted 13/09/20 01:41 AM Share Posted 13/09/20 01:41 AM Have a question for the pro Tuners out there. In my adjustable options ( X4 ) I have - "Turbo Wastegate 40 percent" Currently set at 40 Percent. Not sure what this adjusts exactly. Any info would be greatly appreciated. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,309 Member For: 16y 17d Gender: Male Location: Melbourne Posted 13/09/20 02:07 AM Share Posted 13/09/20 02:07 AM if it's been dyno tuned, don't go messing with the adjustable options at all. Link to comment Share on other sites More sharing options...
FG2XR6T New Member 7 Member For: 3y 9m 27d Posted 13/09/20 02:17 AM Author Share Posted 13/09/20 02:17 AM Its an email/generic tune loaded onto my X4. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,309 Member For: 16y 17d Gender: Male Location: Melbourne Posted 13/09/20 02:19 AM Share Posted 13/09/20 02:19 AM in that case you should definitely go and get a dyno tune as those tunes can easily lunch your motor Link to comment Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,805 Member For: 14y 7m 14d Gender: Female Location: SA Posted 13/09/20 03:23 AM Share Posted 13/09/20 03:23 AM Waiting for pics of lunched motor... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m Gender: Male Location: Perth Posted 13/09/20 04:05 AM Share Posted 13/09/20 04:05 AM 2 hours ago, FG2XR6T said: Have a question for the pro Tuners out there. In my adjustable options ( X4 ) I have - "Turbo Wastegate 40 percent" Currently set at 40 Percent. Not sure what this adjusts exactly. Any info would be greatly appreciated. Would you be happy with 40% for a maths test. 100% where its at........ 2 Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 234 Member For: 5y 11m 18d Posted 13/09/20 04:29 AM Share Posted 13/09/20 04:29 AM before you can understand whats it means you really need to understand boost control. this information is documented everywhere online, start somewhere like here. so then you take that into consideration your actuator set for a desired boost level. anywhere from 4.5 to 9psi on the std ford actuators. then 40 percent is your electronic bleed-off. so if you have a 4.5psi actuator and 40 percent bleed - IN THEROY your getting (4.5psi+1.8psi) 6.3psi. there is about a million things that will affect this, so it wont be cut and dry like doing the math. pro tip, dont play with it. Link to comment Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,805 Member For: 14y 7m 14d Gender: Female Location: SA Posted 13/09/20 05:53 AM Share Posted 13/09/20 05:53 AM 1 hour ago, arronm said: Would you be happy with 40% for a maths test. 100% where its at........ I actual lost my chit! Link to comment Share on other sites More sharing options...
FG2XR6T New Member 7 Member For: 3y 9m 27d Posted 13/09/20 07:05 AM Author Share Posted 13/09/20 07:05 AM Not much help guys. A Tuner will know what wastegate percentage = amount of boost. That was the reply I was looking for. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,309 Member For: 16y 17d Gender: Male Location: Melbourne Posted 13/09/20 07:12 AM Share Posted 13/09/20 07:12 AM Wastegate percentage doesn't even come close to the full story with regard to how much boost you could make. Generic tunes are garbage and destroy motors even in the form you purchased it at. Get a dyno tune and forget about ever needing to care about parameters on the X4. Link to comment Share on other sites More sharing options...
