STFG New Member 6 Member For: 4y 9m 14d Posted 09/09/20 11:03 PM Share Posted 09/09/20 11:03 PM Hi guys have a fg G6et and it has a small fuel leak from somewhere on the tank, have taken the back seat out and it didn’t seem to be coming from the fuel pump housing, smells pretty bad in the car. Only place I can see petrol residue is infrint of the diff area. Any suggestions where to look or what to do? thanks! Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 10/09/20 12:08 AM Share Posted 10/09/20 12:08 AM drop the rear suspension and take the tank out is really your only option if you can't see where the leak is coming from. Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698815 Share on other sites More sharing options...
STFG New Member 6 Member For: 4y 9m 14d Posted 10/09/20 12:22 AM Author Share Posted 10/09/20 12:22 AM I was worried I’d have to do that ☹️, have only had a quick look but I’m assuming the diff cradle needs to come out to remove the tank. Looks like I’ll need a decent mechanic SE Melb, won’t be attempting that myself. Cheers for the reply mate Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698820 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 10/09/20 12:24 AM Share Posted 10/09/20 12:24 AM ring around and find one that worked on falcon taxi's... they'd have the fuel tank removal and inspection process down to a science and wouldn't have high labour rates Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698821 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 25d Gender: Not Telling Posted 10/09/20 12:26 AM Share Posted 10/09/20 12:26 AM You'd be better off getting a camera on a stick aka borescope or use your phone in recording mode for a look, before dropping the cradle out. Ain't nobody got time fo dat. Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698822 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 10/09/20 12:28 AM Share Posted 10/09/20 12:28 AM true, that's probably a better option... the mechanic will have one haha also, if you can see the leak with your borescope but not your fingers/eyes, you'll need to remove the tank to repair it anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698823 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 24d Gender: Male Location: Adelaide Posted 10/09/20 01:06 AM Share Posted 10/09/20 01:06 AM Has you car had an aftermarket fuel pump fitted or any reason the pump module has come out recently ? Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698824 Share on other sites More sharing options...
STFG New Member 6 Member For: 4y 9m 14d Posted 10/09/20 01:55 AM Author Share Posted 10/09/20 01:55 AM Yes it did! Walbro went in 3 weeks ago. I have only just purchased the car and the old owner has said it went back because of the leak and that the O ring was replaced. Still seems to be leaking from somewhere though. I did check under the cradle cap but it seemed dry. I’m assuming you have had this issue? Much appreciate the reply's! Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698827 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 24d Gender: Male Location: Adelaide Posted 10/09/20 04:58 AM Share Posted 10/09/20 04:58 AM (edited) It’s definitely the “O” ring hasn’t been seated correctly, or has the typical dirt/rocks build up on the lip Your leak will only be visible when you fill the car past 3/4 tank and then pop the rear seat out to have a look catch is to fix it you need it lower than 3/4 tank unless you’re willing to waste a 1/4 tank in the process lol Obviously I (and workshops) have drain methods to prove such a thing and fix the re fill the drained fuel Edited 10/09/20 05:00 AM by JETURBO 1 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698842 Share on other sites More sharing options...
STFG New Member 6 Member For: 4y 9m 14d Posted 10/09/20 10:11 AM Author Share Posted 10/09/20 10:11 AM Legend! Thanks heaps mate I will fill the tank tommorw, already got the back seat out ready to look. It was apparently taken back to the mechanics that upgraded the fuel pump so my understanding is that it’s been re fitted already. Just strange it still smells pretty badly of fuel (was fixed 4 days ago) unless there is fuel sitting ontop of the tank that just isnt evaporating quickly. Guess I’ll find out when I fill up lol cheers mate Link to comment https://www.fordxr6turbo.com/forum/topic/95933-fg-turbo-fuel-leak/#findComment-1698845 Share on other sites More sharing options...
