Regany New Member 22 Member For: 4y 10m 25d Posted 03/04/20 12:01 AM Share Posted 03/04/20 12:01 AM Hi Guys just wondering when upgrading to a walbro 450lph fuel pump in a fg f6 do you need to upgrade the wiring or will it be able to handle the amps that it puts out? Also will it require a new regulator? And if so when fitting a new regulator do you just set them to 4 bar on stock tune before heading to tuners ? Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,304 Member For: 16y 16d Gender: Male Location: Melbourne Posted 03/04/20 12:06 AM Share Posted 03/04/20 12:06 AM it's reasonably fine to have a basic lift pump (255lph) on the stock fuel pump wiring, but a 450 is pushing it and you'll be wanting to think about upgrading the wiring. you don't strictly need a new regulator until over 400kw. if you get a new regulator, yes, you match the fuel pressure to stock (which is correct at 4bar) and then head to the tuner... or get the tuner to fit it. Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y 4d Gender: Male Location: Melbourne Posted 03/04/20 12:22 AM Share Posted 03/04/20 12:22 AM Definitely should upgrade the wiring.Here’s how I did it works well. Only thing I changed from this photo is the earth to the seat belt buckle instead of next to the cap on the cradle. Link to comment Share on other sites More sharing options...
Head Member 74 Member For: 13y 8m 5d Posted 03/04/20 01:18 AM Share Posted 03/04/20 01:18 AM it's reasonably fine to have a basic lift pump (255lph) on the stock fuel pump wiring, but a 450 is pushing it and you'll be wanting to think about upgrading the wiring. you don't strictly need a new regulator until over 400kw. if you get a new regulator, yes, you match the fuel pressure to stock (which is correct at 4bar) and then head to the tuner... or get the tuner to fit it.Stock regulator with a 450 will not be able to return the excess fuel to the tank fast enough and then the pressure will go through the roof. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,304 Member For: 16y 16d Gender: Male Location: Melbourne Posted 03/04/20 01:21 AM Share Posted 03/04/20 01:21 AM I've seen 450's be OK at lower power levels with regard to fuel return. Link to comment Share on other sites More sharing options...
Head Member 74 Member For: 13y 8m 5d Posted 03/04/20 01:24 AM Share Posted 03/04/20 01:24 AM Yeah I’m not talking about power levels, I’m talking pressure. The 450 flows so much fuel that the stock reg return becomes a bottle neck and you’ll see pressures around 100 psi not 58 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,304 Member For: 16y 16d Gender: Male Location: Melbourne Posted 03/04/20 01:26 AM Share Posted 03/04/20 01:26 AM with the lower amount of amps being pulled by the stock wiring, the pressure doesn't get ridiculous... if you upgrade the wiring of course that's likely to happen. Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y 4d Gender: Male Location: Melbourne Posted 03/04/20 01:35 AM Share Posted 03/04/20 01:35 AM You can drill out the standard reg, works fine for me 2 Link to comment Share on other sites More sharing options...
Regany New Member 22 Member For: 4y 10m 25d Posted 03/04/20 03:40 AM Author Share Posted 03/04/20 03:40 AM How many kw are you making boostedg6e with drilled out reg? Was it a big job to do wiring did u run it from battery back with fuse and relay ? Or splice into the original circuit somewhere ? Link to comment Share on other sites More sharing options...
BoostedG6E Member 105 Member For: 6y 4d Gender: Male Location: Melbourne Posted 03/04/20 03:49 AM Share Posted 03/04/20 03:49 AM Car made 440RWKW. Yeah Power and earth straight from the battery, put everything through passenger side firewall grommet then through passenger side kick panels. and relay and fuse is mounted in my first photo, Tapped into the original trigger wire for the relay. Fuse wasn't put in at the time of the photo it was put in just after. my brother is the wiring guru I just helped out man so can't comment to much on the difficulty but was all done in a day. That's including modifying cradle drilling the new holes to fit the bulkheads. Link to comment Share on other sites More sharing options...
