  • Member For: 11y 7m 9d
Posted
Hey all, Happy long weekend. Have a leaking seal in housing, pretty sure it's leaking from coolant pipe. Have tried removing pipe too replace this seal, But cannot move it?? Any pointers would be appreciated. bf1cd68f9b147cec83d0766f30839089.jpg
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 5m 6d
Posted
can't see any obvious signs of coolant leakage there...
Posted
Hey there ,been looking before every start up, it's always wet on the bottom of the housing? Have had it pressure tested ??was told no leak! Has been this way for about 2 months when I first noticed coolant dripping a little bit under the car.
  • Site Developer
Posted
ok... must be when it cools down that it allows a drip or two to get out.
so what's the actual problem? which part are you having trouble removing?
Posted
That single pipe ,that has the one bolt , on the bottom housing. &how do I turn off simple functions on taptalk.??
  • Dropping a turd
  • Legacy Donating Member
  • Member For: 18y 10m 20d
Posted
In that image there are 4 locations it can be leaking from.
Hose at thermostat.
Thermostat to housing
Turbo feed.
O ring at pipe.
Posted
I thought I would replace that seal where that pipe goes in with the bracket! I read somewhere on the site they just pull the pipe out enough to replace seal!! Have tried, it will not move?I didn't think it would
Sorry wrong hole.
Sorry lads.
  • Site Developer
Posted
turn off your tapatalk signature. it's in the settings on the app.
