Locko90 Member 32 Member For: 6y 1m 4d Posted 20/09/19 11:37 PM Share Posted 20/09/19 11:37 PM G'day fellas, I'm in the process of changing my stock boost actuator to a new 12psi turbo smart actuator. I decided that I would take the exhaust manifold off with the turbo still attached. so I went ahead and disconnected all water and oil lines from the turbo. Removed dump pipe, intercooler piping and exhaust manifold. And this is where I've hit abit of a road block taking the turbo off, there seems to be a bracket on the side of the block that is holding the turbo and exhaust together (shown in pictures) How would I go about getting these bolts out? And are there anymore hidden bolts I might need to get out Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,491 Member For: 17y 1m Gender: Male Location: Melbourne Posted 21/09/19 01:11 AM Share Posted 21/09/19 01:11 AM Yeah, that bracket is a real PITA. You can either undo it from the two bottom manifold-to-turbocharger nuts or you can undo the one you have an arrow going to along with the one that's in the middle of the engine mount (use a spanner shaped like a "table top" to get onto the one in the middle of the engine mount) 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688575 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 9d Gender: Male Location: Adelaide Posted 21/09/19 05:13 AM Share Posted 21/09/19 05:13 AM I strongly suggest not fitting a TS 12 psi actuator unless you’re very experienced in using the TS actuators. Use a Garrett Genuine 11.8psi actuator or let your tuner fit the T/S one as I’ll almost guarantee they will need to adjust it again Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688585 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,491 Member For: 17y 1m Gender: Male Location: Melbourne Posted 21/09/19 05:15 AM Share Posted 21/09/19 05:15 AM post up a video tutorial of setting one up, J@? Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688586 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 9d Gender: Male Location: Adelaide Posted 21/09/19 06:30 AM Share Posted 21/09/19 06:30 AM Yeh, nar every application is very different hence why the TS actuators have mixed reviews as it’s very specific Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688589 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,491 Member For: 17y 1m Gender: Male Location: Melbourne Posted 21/09/19 06:35 AM Share Posted 21/09/19 06:35 AM rightio... seems a bit weird but ok 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688590 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 9d Gender: Male Location: Adelaide Posted 21/09/19 06:43 AM Share Posted 21/09/19 06:43 AM Not all actuators are linear in movement vs input unfortunately so every application reacts differently and you need to see how a TS actuator works ( very unforgiving ) The Garrett range are very good to providing somewhat of a linear motion hence why it’s a almost dummy proof arrangement for newbs 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1688591 Share on other sites More sharing options...
xr6thsveta Donating Members 100 Member For: 13y 6d Gender: Male Location: Palmerston North. New Zealand Posted 13/11/19 10:32 AM Share Posted 13/11/19 10:32 AM On 21/09/2019 at 5:13 PM, JETURBO said: I strongly suggest not fitting a TS 12 psi actuator unless you’re very experienced in using the TS actuators. Use a Garrett Genuine 11.8psi actuator or let your tuner fit the T/S one as I’ll almost guarantee they will need to adjust it again Hi, do you have a Link to where I can buy a Garrett Genuine 11.8psi actuator for a BA? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1689862 Share on other sites More sharing options...
Locko90 Member 32 Member For: 6y 1m 4d Posted 13/11/19 07:09 PM Author Share Posted 13/11/19 07:09 PM I've allready installed it, it's been on there for about 2 months no real noticeable difference..Boost comes on slightly quicker, but I'm in the process of fixing the exhaust and then needing a tune. Link to comment https://www.fordxr6turbo.com/forum/topic/95223-remove-turbo-actuator-actuator-upgrade/#findComment-1689868 Share on other sites More sharing options...
