Typhoon196 New Member 5 Member For: 4y 11m 1d Posted 06/06/19 03:37 AM Share Posted 06/06/19 03:37 AM How do you remove/get to the turbo oil feed on the side of the block on a BA Typhoon with the fpv engine oil cooler in the way? Mine has blocked and blown the turbo I have fitted a new turbo but can't seem to get to the oil feed to replace the stock oil line with the new oil line?! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,334 Member For: 16y 27d Gender: Male Location: Melbourne Posted 06/06/19 04:39 AM Share Posted 06/06/19 04:39 AM you need a couple of 22mm spanners, one cut in length so that it fits on the "rear of engine" side of the banjo-bolt. You hold the block-side of the banjo bolt so that the oil line does not rotate and then on the other side turn the outer banjo around. The electrical leads are easily removed from the "hat-shaped" sender part on the end that the typhoon has. Link to comment Share on other sites More sharing options...
Typhoon196 New Member 5 Member For: 4y 11m 1d Posted 06/06/19 04:51 AM Author Share Posted 06/06/19 04:51 AM From the top or bottom? I can't even touch it with my hand let alone get a spanner on it.... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,334 Member For: 16y 27d Gender: Male Location: Melbourne Posted 06/06/19 04:56 AM Share Posted 06/06/19 04:56 AM you take the airbox out and attack it from above and go in under the intake manifold with your hands. Link to comment Share on other sites More sharing options...
Typhoon196 New Member 5 Member For: 4y 11m 1d Posted 06/06/19 05:36 AM Author Share Posted 06/06/19 05:36 AM That's the way I tried, looks like the Intel manifold is coming off. Replacing the turbo was easy this oil line is a pain it's the only thing stopping me from driving it. I can't even drive it somewhere to pay someone to do it! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,334 Member For: 16y 27d Gender: Male Location: Melbourne Posted 06/06/19 05:38 AM Share Posted 06/06/19 05:38 AM just trailer the car to a mechanic or get a mobile mechanic to help you? Link to comment Share on other sites More sharing options...
Typhoon196 New Member 5 Member For: 4y 11m 1d Posted 06/06/19 06:05 AM Author Share Posted 06/06/19 06:05 AM Thanks for the info, intake manifold is coming off then. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,334 Member For: 16y 27d Gender: Male Location: Melbourne Posted 06/06/19 06:06 AM Share Posted 06/06/19 06:06 AM it's harder to take off the intake manifold than it is to get your arms/hands in underneath it... Link to comment Share on other sites More sharing options...
Typhoon196 New Member 5 Member For: 4y 11m 1d Posted 06/06/19 06:46 AM Author Share Posted 06/06/19 06:46 AM I must have big hands, the oil cooler sandwich plate is in the way... And I can't see to put it back together anyways maybe pull motor out will be easier haha or burn it one of the two! Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 6m 10d Gender: Male Location: Perth Posted 06/06/19 07:14 AM Share Posted 06/06/19 07:14 AM (edited) Take oil filter and oil cooler off. Its a 24mm long reach socket. But you need to hold the fitting with 24mm open ender. It's a taper fit into the block so don't overtighten it. It's a tricky job , maybe get a mechanic to do it. If you car has high k's good idea to change the inlet gasket any rate. What state you in. Look here. Half way down the page What type of new line do you have. Don't forget to remove the small filter from the fitting and leave it out. https://www.fordforums.com.au/showthread.php?t=73561 Edited 06/06/19 07:27 AM by arronm Link to comment Share on other sites More sharing options...
