Ascendancy254 New Member 7 Member For: 6y 9m 5d Posted 11/09/18 10:33 PM Share Posted 11/09/18 10:33 PM Hi All Long time reader, first time member, not lucky enough to have a turbo yet but the plans are for my XE to go that way (when the missus lets me buy what I need!) Long running issue with my N/A BA Falcon Ute (4.0 5 speed) which no-one has been able to help with, so here I am, asking the experts! Story as follows - Car was running like a dog so decided to treat it and replace everything that needed to be done - New Rear Exhaust (REDBACK) New Cat and centre muffler New Exhaust Manifold Gasket(s) New Intake Gasket New Plenum Gasket New TB Gasket Reco Throttle Body New TPS Sensor New MAP Sensor New Fuel Pressure Reg. (2.7 bar standard) Fuel Rail Removed and Cleaned New Injectors (295cc Standard) New Air Filter New Rocker Cover Gasket and Plug Seals New Iridium Plugs New Coil Packs New Thermostat New Battery Terminals New Alternator New O2 Sensor (Three times - Still do not know if the others were faulty) 19.5 - 20 inHg of Manifold Vacuum Approx 1L of fuel return in 60 seconds (close enough to without fully measuring) Been to independent Mechanic No idea? Been to Ford dealer No Idea? (side note, DO NOT EVER GO TO FORD ON BURWOOD HIGHWAY VICTORIA - LYING PACK OF THIEVES!!!) Ex Toyota Technician Checked No Idea? (neighbour) Issue - fault code P1132 - Car is using about 16 - 17L/100km (up from 10.5 - 11L/100km) I have spent a small fortune on this car over the past few months and still have not been able to find or fix the issue! Anyone can finally give me the answers I need will have either a bottle of scotch / whiskey / bourbon or a slab (up to $150) sent directly to them (or handed over in person if you are close enough) as it is currently costing me $160 a week in fuel and my sanity!!!! Live in Epping Vic, car is in Bayswater Vic. Any help would be amazing! Cheers in advance Shane Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/ Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 5d Posted 11/09/18 10:56 PM Author Share Posted 11/09/18 10:56 PM Forgot to mention, RECO PCM with latest software installed Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663900 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,558 Member For: 17y 2m 7d Gender: Male Location: Melbourne Posted 11/09/18 11:02 PM Share Posted 11/09/18 11:02 PM with everything you've changed there; (which is basically everything) the only guesses I'd have are the following: - Previous owner had it tuned but never told you and it's expecting to be modified (pretty unlikely - extremely unlikely based on your 2nd post) - Skipped a tooth on the timing chain. - PCV circuit is blocked or not working correctly so airflow is causing issues there. Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663901 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 18d Gender: Not Telling Posted 11/09/18 11:14 PM Share Posted 11/09/18 11:14 PM Haha the last time someone offered beer I gave them a 100% workable solution and they decided that they'd rather send the beer to someone else. No help for you. Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663902 Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 5d Posted 11/09/18 11:20 PM Author Share Posted 11/09/18 11:20 PM Hi K31th, really appreciate the input. I have changed the PCV 2 or 3 times now (I have done that much I am forgetting things) to no avail. Air flow through the Vacuum hose is good and there appears to be no blockages but I did not that when the TB is to open air (air box and piping removed) and I put a vacuum gauge in to the vacuum hose to the intake manifold, the car either tries to or does stall... I have also noticed the butterflies within the plenum are chattering even though the vacuum actuator is fully closed... not sure if this helps? I am also getting 19.5 - 20inHg at the fuel pressure regulator BUT when I remove this vacuum line, nothing seems to change? Even though the reg is new and I am getting the 1L in 60 sec return, could the reg still be faulty? Hi Puffwagon hahaha I know your pain on that one as well so no dramas bloke! If you decide to change your mind the offer stands! Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663903 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 18d Gender: Not Telling Posted 11/09/18 11:30 PM Share Posted 11/09/18 11:30 PM Haha all good mate, I was just being a turkey. Is the wiring to the O2 sensor all good? It's not burnt, broken or corroded or anything like that? Is the plug clean? Are the pins properly seated? If it's filled with oil, water or has corrosion on it then that would be something to fix up. Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663904 Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 5d Posted 11/09/18 11:40 PM Author Share Posted 11/09/18 11:40 PM Hi Puffwagon Connector is clean and free of debris and any other collective garbage. Getting full voltage at the connector and resistance is where it should be on the heating element (as per workshop manual) I have run some live data (using FORSCAN) and everything seems to be where it should be? (unless I am reading it wrong?) Manifold pressure at idle is 33kPa with a MAP voltage of 1.36V (for memory) and the voltage moves with the manifold pressure as it should. After memory clear (battery D/C for 24 hours), the car will start and idle great for about 2 minutes (roughly, might be less?) and then cough splutter and fart and go like a dog again. Do you know how long cold start runs for? Could it be the CHT is faulty but not showing up as such and the car is stuck in cold start mode? The O2 keeps coming up with Open Loop fault when running data as well Really appreciate the time guys! Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663907 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,558 Member For: 17y 2m 7d Gender: Male Location: Melbourne Posted 12/09/18 01:15 AM Share Posted 12/09/18 01:15 AM since you're in bayswater, take it to nizpro around the corner and get them to diagnose it for you Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663909 Share on other sites More sharing options...
Ascendancy254 New Member 7 Member For: 6y 9m 5d Posted 12/09/18 01:23 AM Author Share Posted 12/09/18 01:23 AM Any idea what they charger K31th? I've already spent a small fortune and I am quickly running out of money! Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663910 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,558 Member For: 17y 2m 7d Gender: Male Location: Melbourne Posted 12/09/18 01:45 AM Share Posted 12/09/18 01:45 AM well, if you just make sure they are instructed to only diagnose, it won't be prohibitively expensive, but they're a performance workshop, so they won't be cheap in terms of labour rates Link to comment https://www.fordxr6turbo.com/forum/topic/94258-running-rich-poor-economy/#findComment-1663911 Share on other sites More sharing options...
