March 3, 20188 yr #1 Hi guys how are we? Hey I am stuck and need help, I am looking at getting process west stage 2.2 which comes with under battery air intake, throttle body relocation and intercooler of course. I’m confused with The boost sensor that is located under the battery, how does it connect up to the new setup? As the under battery intake replaces the intercooler pipe where it is attached to from factory. I am doing this cause I have recently had ALOT of blow by all threw my pipes and intercooler so I’m replacing the lot and getting a catch can to hopfully stop the blow by. Any help would be great! Thanks guys
March 3, 20188 yr #2 Just an FYI; replacing the piping won't affect how much blow-by you get in said piping. The catch can, if installed correctly, will help with that situation, whether you get new intercooler piping or not. When you get a replacement kit, you usually get a loom extension with the kit that allows you to move the sensor to a new location which has a point where you can install the factory sensor piece.
March 3, 20188 yr #3 Author Thanks for yur reply! Yes I know that replacing the piping won’t help the blow by, but when the catch can is installed I don’t want to have rubber pipes with oil embedded into them on there, cause it will just send oil threw everything again. Ok thank Yu, just after advise from people and what they know. And when installing catch can Yu plum from the rocker cover breather ( near throttle body ) to the can, then plum back to the pipes after the air filter correct?
March 3, 20188 yr #4 35 minutes ago, k31th said: loom extension Aka a 3/4 of a car width of one and a half pieces of speaker wire
