Tomxr6 New Member 3 Member For: 10y 3m 1d Posted 19/11/15 09:54 AM Share Posted 19/11/15 09:54 AM Hi guys I'm new to the forum finally ended up buying Ba xr6 turbo a few months back as a project I'm in the process of fixing all the little Ba gremlins so I can get it registered Atm I'm trying to repair the central locking the car won't lock itself and stay locked seems to be intermittent locks when it wants for a few minutes then unlocks and sometimes won't lock at all it won't lock with remote, key ,or the button on the dash And also the interior light stays on car only locks when interior light dims out ???????So far I've ended up changing every door actuator including the boot with no luck changed every door wiring loom as I found a exposed wire in the one on the c pillar fixed it still nothing cleaned all connections with contact spray didn't help nothing seems to be helping For some strange reason every time you open and close the rear left door very slowly it seems to dim out the interior light for a bit and then after a few minutes the interior light will come back on and the doors will unlock I've changed the actuator on this door twice but nothing it's really doing my head in I have been told it might be the the bcm module but I'm sort of hoping it's not if anyone has any info or has had this same problem any advice will be much appreciated as I'm losing my mind lol cheers Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/ Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 9m Gender: Male Location: Melbourne Posted 19/11/15 10:01 AM Share Posted 19/11/15 10:01 AM I think it happens a bit. My 2004 BA XR6T had it after really unseasonal heavy rain one day. It went away by itself - I suspect some water leaked in somewhere in a door and shorted somewhere and after things dried out - its been okay ever since. Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570871 Share on other sites More sharing options...
Tomxr6 New Member 3 Member For: 10y 3m 1d Posted 19/11/15 10:06 AM Author Share Posted 19/11/15 10:06 AM Hi thanks yeah from what I'm reading on the net seems to be a big issue with the b series was hoping it was water somewhere but have found nothing but ill keep looking next step will be to remove the icc and check the wiring there fingers crossed Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570873 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 29d Gender: Male Location: Adelaide Posted 19/11/15 10:34 AM Share Posted 19/11/15 10:34 AM Maybe the rubber button that pushes in when you close the the door might be farked. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570879 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 15d Gender: Male Location: Brisbane Posted 19/11/15 10:39 AM Share Posted 19/11/15 10:39 AM ^^ the clue is in the interior light behaviour... Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570883 Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 16y 9m 18d Gender: Male Location: Perth, Western Australia Posted 19/11/15 10:45 AM Share Posted 19/11/15 10:45 AM Not a whole lot of help here, but how I replaced the broken cog in an actuator last year: http://www.fordxr6turbo.com/forum/topic/89014-photo-essay-central-locking-repairYou can get repair kits via eBay. Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570885 Share on other sites More sharing options...
Tomxr6 New Member 3 Member For: 10y 3m 1d Posted 19/11/15 10:51 AM Author Share Posted 19/11/15 10:51 AM I wish they had the rubber button they are actually built in to the door actuator would of made life a lot Easyer as you could check each individual door for the fault Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570888 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 5m 4d Gender: Male Location: WA, Perth Posted 20/11/15 12:51 AM Share Posted 20/11/15 12:51 AM ^^ the clue is in the interior light behaviour...Ahh dude, you being a Karnt... he said he has no idea and has come to the forum for assistance.I doubt he will do the running thing, cause he has been on the forum for 9 months.Ohh and you are a Karnt cause you got me in suspense now, especially this early in the morning.I know you got the answer, but I can't think....Sounds like the door sensor/switch/actuator is not tuned properly????SPIT IT OUT ALREADY!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570966 Share on other sites More sharing options...
velocityxr6t Member 122 Member For: 16y 5m 22d Gender: Male Posted 20/11/15 02:23 AM Share Posted 20/11/15 02:23 AM ^^ the clue is in the interior light behaviour...The car thinks a door is open? If it was this it'd do the three quick, hey idiot you pushed the button before closing the door so I'll alert everyone in the area to your shame beeps? Or if the sensor is in and out, does it then do as descirbed?IE. the bcm gets a initial signal of all doors closed, so locks without the three beeps of shame, then the signal becomes door open, the bcm then unlocks all doors as a default because you can't have doors opened and locked.Go around the car. Open each door one at a time and press in the door open/closed sensor (bad terminology I know) and see if the all effect the interior light equal. If they do, try again as it may be intermittent. Link to comment https://www.fordxr6turbo.com/forum/topic/91404-ba-xr6-turbo-central-locking-problem/#findComment-1570986 Share on other sites More sharing options...
