Fans - Anyone Got A Easy Way For Me To Trigger Them Manually As Requir
Featured Replies
#1
Fans - Anyone Got A Easy Way For Me To Trigger Them Manually As Required
They never turn on but would like them on for staging and things like that.
BFII XR6 Turbo
315kw at rear
Edited by gbp
#2
Chuck a switch over the fan relay? Not gonna be super easy though if you don't know what you're doing
#3
X2 Lengths of cable
One red with a female blade connector on one end and a suitable battery terminal connector on the other
Repeat for black
Pull the thermo fan connection pin block off the fans
Connect new fly leads to fan connection input
Connect to battery
Get fancy and put a switch in it
Or you can have a drag tune with the fans to come on and stay on from early temps
Your tuner would more than likely do this for next to nothing
Cheers
#4
Are the fans normally fused? Could see the motors drawing more as they get old and burning wire doing it that way... plus they wouldn't go on automatically anymore?
Drag tune ftw.. my fans are always on now it's been tuned if I give it a flogging
#5
  • Author
ok, drag tune sounds like the go
cheers
#6
I'm fairly certain I tried this once. With a simple power and earth to the battery and chassis. They pull a ridiculous amount of current on start up and I was blowing 15amp fuses instantly. Wasn't game to go further as was only running 15amp wire.
I would recommend a relay if your trying to run a switch.
#7
  • Author
Ended up triggering 1 fan with a 30a switch, no relay - does the trick
#8
You're welcome
Recently Browsing 0
