jas98 Member 1,048 Member For: 12y 10m 22d Gender: Male Location: Maryborough Qld Posted 10/08/15 04:50 AM Share Posted 10/08/15 04:50 AM Hi. Ba xr6t sedan 4speed auto.Last couple weeks I have noticed that when giving it a bit ( stock 6psi) and backing off ..if I back of quickly the whole car thups/jolts and sometimes its pretty dam bad. Feels like its comming from gearbox. The center bearing is split but surely that would be a thump not jolt/ thump/ whole car thumps which makes everything in car jolt including myself and passenger.Could be me but seems like it does it more when cars cold....now it has done it in past but seems to be doing it more often. So could gearbox do this? Cause if it can I'm suprised it didn't break anything Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/ Share on other sites More sharing options...
rokkie Member 87 Member For: 12y 8m 26d Gender: Male Location: Adelaide, SA Posted 10/08/15 09:54 AM Share Posted 10/08/15 09:54 AM Worn diff bush's maybe? Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557315 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 9d Gender: Male Location: Adelaide Posted 10/08/15 10:35 AM Share Posted 10/08/15 10:35 AM Bearing in the tailshaft? Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557319 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 6m 24d Gender: Male Location: Melbourne Posted 10/08/15 11:01 AM Share Posted 10/08/15 11:01 AM 4 Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557325 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 21d Gender: Male Location: Probably above atmospheric pressure Posted 11/08/15 05:51 AM Share Posted 11/08/15 05:51 AM Hahaha saw that on FB yesterday, worth a giggle.OP, I've had the same bang noise in my ZF for a long long time, I think it's the entire driveline having that overall slack in it. It was mostly better after I recently got new tailshaft centre bearing/Uni and mount to gearbox but came back again soon after. My car has over 275,000km on it, I drive it hard often. Diff is surely worn as well.Also, try to avoid giving it WOT and then stepping off the go pedal, some theories around that it can contribute to the timing chain skipping teeth (not to mention the massive bang) Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557449 Share on other sites More sharing options...
jas98 Member 1,048 Member For: 12y 10m 22d Gender: Male Location: Maryborough Qld Posted 11/08/15 04:24 PM Author Share Posted 11/08/15 04:24 PM Thanks for all helpvsnd suggestions. The diff is nice ant tight. Has been recoed. The tail shaft however does need attention. The center bearing is almost split the whole was round and the CV joint to diff does have some play. One thing I have noticed is seems to have a very rough idle at lights recently so maybe a engin monunt has torn...or gearbox mount.......hopefully not a timeing problem.....could I check with forscan?? If its skipped?? Although seems too be idling at 700 rpm....normally 750 rpm Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557538 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 21d Gender: Male Location: Probably above atmospheric pressure Posted 12/08/15 11:01 AM Share Posted 12/08/15 11:01 AM If it's an engine mount follow my advice and just get a genuine one put in, don't go aftermarket, if they fail soon after you put them in it's a royal PITA, I had one die twice and finally opted for normal again. Turbo side exhaust leak possibly killing it mind you. Link to comment https://www.fordxr6turbo.com/forum/topic/90971-is-my-gearbox-stuffed/#findComment-1557638 Share on other sites More sharing options...
