  • New Member
  • Member For: 11y 2m 8d
Posted (edited)
Hi guys
I've recently installed boost gauge, oil temp gauge and a turbo smart manual boost tee controller in my fg xr6 turbo. But as soon as I turn the boost up even a tiny bit, the ecu puts up the engine light and turns the boost from 12 psi to about 8, is that normal?
Sent from my GT-I9505 using Tapatalk
Edited by kunwar.xbox
  • Legacy Donating Member
  • Member For: 20y 9m 17d
Posted
Yep, normal.
The ecu is to smart for a boost tee.
You need to have it tuned with HP tuners or SCT and xcal if you want to increase the boost above factory calibrations and thresholds.
  • Member For: 13y 3m 3d
Posted (edited)
This isn't your average ricebox son. The B series ecu's can be a little sensitive to change. And you've sort of gone the wrong way about trying to achieve your goal there. As stated, you need an xcal and a tune from someone that knows what they are doing.
Btw, a warm welcome to the forum mate : )
Edited by FiftyOne
  • New Member
Posted
Cheers guys, I knew it would go into limp mode without a tune but, also I think the boost controllers not working at its best coz it's on stock boost atm but it's still over boosting... maybe I need to check the setup again. I'll keep youse updated thanks.
  • Member For: 15y 5m 24d
Posted
There is a lot more involved than winding the boost up when getting a tune. Your best off saving a little and getting tune and injectors with the xcal.
Sent from my iPhone using Tapatalk
  • New Member
Posted
Yeah I am thinking about removing the boost controller and might get an xcal 4 and do it myself... yeah 1500 from monster torque which would probs be safe aswell
