  • New Member
  • Member For: 15y 6m 8d
Posted
So story goes, had just started driving home (8-10km drive) and noticed the speedo wasn't working (km/hr), then when I was nearly home the etc light came on and it went into limp mode, luckily I was only 1km from home, so I just limped home.
Once home I turned it off, locked it, then unlocked it and started it, it started fine, I reversed down the driveway and drove back in and everything is working fine again.
Does anyone know what's going on?
Will be seeing a mechanic 2moro, last service was only 600kms ago, battery and alternator replaced about 5000kms ago
It's a bf2 f6 ute.
Any help will be mu hoy appreciated
  • Member For: 12y 10m 3d
Posted
Sounds kinda like the abs module has shat itself. Was it just the speedo not working or entire dash.
Do u have the facilities to scan for codes?
  • New Member
Posted
Was just the speedo.
Will take to mechanics for scan tool today hopefully
  • 10 months later...
  • Legacy Donating Member
  • Member For: 15y 17d
Posted
My BF F6 is doing the same.
What was the problem Jhols1?
  • Member For: 13y 2m 21d
Posted
BF F6 ute here, did some strange things with the speedo for a while. Intermittent; but I think I found a loose earth and after Ive torqued it back up everything seems good.  Can't say that was the exact cause however, I think mine was a canbus fault as it didnt throw a code.
Posted
Where was the loose earth?
Posted
Under the airbox on the headlight loom. Had green corrosion around it. bit of emery to clean everything and she's good
Posted
Thanks FityOne!
Posted
No haven't had a chance to look at it maybe next weekend
