  • Member For: 11y 11m 29d
Hi guys need help with changing actuator on stand fg turbo! Ques is how hard is to change? Is worth it to change? Wat to get? And if some workshop do it hw much it cost? Do we need tune after changing actuator?? Thxx
https://www.fordxr6turbo.com/forum/topic/90419-fg-turbo-actuator-change/
  • 3 years later...
  • Member For: 6y 7m 14d
Hi guys, if I'm going to get a gt35r and a new wastegate actuator and run say a max of 17psi, should I get a 12 psi actuator or a lower one? I realise I won't be able to run less than 12psi and I'm happy with that, but would a 12 be the right choice? Also on trademe here in nz there's a xr6 turbo replacement fg turbine housing, not a garrett one, and it is advertised as thicker casting and heavier and has a 34mm wastegate hole and has bigger flapper to suit 595nz$ sounds not bad to me, but is it junk? Opinions please, thanks
@JETURBO can you help me with my post in fg actuator change please?
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 17d
Donate $20 to the forum and I’ll answer all your questions and get you good prices on parts ...
how does that sound ?
  • Haha 1
Sounds great, I'm working on it 747, on holiday at moment, iv got to find out my PayPal password at home when I get back tomorow. So you can hand over some answers, I'm good for it lol, thanks
@Puffwagon hi can you help me out?
By the way the turbine housing I mentioned is brand new.
