FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m 19d Gender: Male Posted 28/07/14 10:57 AM Share Posted 28/07/14 10:57 AM Never been a huge fan of the turbo spooling noise, I love the ute right now becuase of the fact it isn't loud & over stated. Any way to make the drivers side airbox replacements a little quiter? I'm thinking of using an FG intake muffler somehow. Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/ Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 7m 28d Gender: Male Location: Perth, WA Posted 28/07/14 01:52 PM Share Posted 28/07/14 01:52 PM (edited) Go back to oem intake? Or otherwise wrap the pod filter in duct tape. Edited 28/07/14 01:54 PM by XtRmn8 Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488238 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 6m Gender: Male Location: Brisbane Posted 28/07/14 09:51 PM Share Posted 28/07/14 09:51 PM Trouble is the fg intake muffler does a 180 pretty much, there doesn't seem like enough material to cut it down but you never know if you don't try. You could perhaps make your own it's a simple enough concept. I just wonder if it's having the baffling right on the bend that makes it work in the first place?Or as above go back to stock lol? Why go turbo side if you don't like spool? I will swap you an entire stock fg setup for a turbo side Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488254 Share on other sites More sharing options...
jules_1972 Member 39 Member For: 15y 5m 15d Gender: Male Posted 28/07/14 10:44 PM Share Posted 28/07/14 10:44 PM ^^^ WHS ^^^Just keep the intake all stock. Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488263 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 16d Gender: Male Location: Townsville Posted 29/07/14 04:33 AM Share Posted 29/07/14 04:33 AM Have you tried lining the airbox with sound deadener and then the inch thick foam sound absorber?Obviously you have to leave where the air enters open (under headlight?) but seal off everywhere else around it and atleast then the airbox is as best it can be!As for the muffler, surely you can buy a big plastic oil funnel (8inch) and cut it off at the intake pipe size (3-4inch) and go from there?Regardless though, make sure you take photos of it for us all and good luck with it.... Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488318 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m 19d Gender: Male Posted 29/07/14 08:51 AM Author Share Posted 29/07/14 08:51 AM Well I'm pretty keen to mod an airbox on the existing side & leave the battery where it belongs. Failing that I'll do the swap. I want to develop a 3d printed box actually, either side that uses a stock panel. Think it can be done Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488364 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 16d Gender: Male Location: Townsville Posted 30/07/14 05:41 AM Share Posted 30/07/14 05:41 AM If you have a 3d printer and the software can mirror image the original intake box then I can't see why not! It would be cheaper though to make the usual 4in intake on the battery side and insulate it and I'd say the noise level would be similar in the end anyway...Depending on what power you want to chase you may be better off just leaving the original box in place and make some bigger piping to the turbo! Link to comment https://www.fordxr6turbo.com/forum/topic/88835-muffler-after-battery-delete/#findComment-1488598 Share on other sites More sharing options...
