  • Member For: 12y 3m 26d
Posted
Saw this braided oil feeding line kit for fg turbo. Has anyone done it? Is it easy to fit? I change my oil every 9k and only use good oil. Are they more like an peace of mind or they really worth the effort? Thanks
  • Member For: 14y 9m 21d
Posted
I just removed the inbuilt filter and no problem
Reckon looks neat with the stock line instead of the braided one
  • Member For: 14y 9m 12d
Posted
I pulled the stock filter fitting off my BF at about 50K and replaced it with a new factory stocker. The old one had miniscule amounts of debris in it and got cleaned ready for the next changeover. The braided kits look the goods and heaps of the forum people use them. IMO, quality oil and regular changes is step one. Getting these filter fittings things out of the block is P** easy and if they are clean........ leave it alone.
I have nothing other than a gut feel but I am not a fan of removing the micro filter from the fitting.
  • Member For: 13y 6m 30d
Posted
I found it quite difficult but I'm special when it comes to work in engine bays. Worth the piece of mind I reckon and it looks cool too. Pretty cheap also
  • Member For: 12y 10m 5d
Posted (edited)
I was of the same opinion in regards to just removing the screen, so I went with the after market solution. On the off chance the motor sh*ts itself id rather a little bit of metal didn't make it to the turbo, even worse gets stuck in the banjo for a while and kills your turbo after a motor rebuild. Ridiculous scenario I know but one ill never have to worry about. So easy to clean the after market filters also. Do mine every oil change.
Also I think Aaron once said the factory screens are so fine, even if you clean them to the naked eye, they can still be blocked. Bin the old one.
Edited by barnz
