beastrado Member 23 Member For: 11y 2m 17d Posted 30/04/14 09:55 AM Share Posted 30/04/14 09:55 AM Hi everyone I'm having some issues with my 6 speed manual. It is an 09 xr6t ute.When changing from 1st to 2nd it is hesitant and ever so slightly grinds. The best way ive found around this is to slowly pull the gear knob from first gear into neutral for a short time and then into second (if that makes sense).The ute had 8000kms when I bought it and changed all fluids straight away. I used castrol transmax z. Now has 27000kms but has done it ever since I purchased the vehicle.Any advice is appreciated cheers. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 6m 7d Gender: Male Posted 30/04/14 11:06 AM Share Posted 30/04/14 11:06 AM Mine does it. Worse when cold. But once warmIt's ok. Plenty if FGs do it. Notchy shiftys aswell don't help. Link to comment Share on other sites More sharing options...
beastrado Member 23 Member For: 11y 2m 17d Posted 30/04/14 11:18 AM Author Share Posted 30/04/14 11:18 AM Mine does it. Worse when cold. But once warmIt's ok. Plenty if FGs do it. Notchy shiftys aswell don't help.Yes its worse when cold but still there when warmed up. I'm going to try mainlube gear oil at 30000km and see how that goes. Link to comment Share on other sites More sharing options...
visine Member 144 Member For: 11y 6m 17d Posted 30/04/14 11:27 AM Share Posted 30/04/14 11:27 AM One of the pleasures and pain of owning a manual. Never had 6060 box but had t56 and the noises,clunks,bangs & roll over that came out of that box. So in short it's normal. Link to comment Share on other sites More sharing options...
beastrado Member 23 Member For: 11y 2m 17d Posted 30/04/14 11:37 AM Author Share Posted 30/04/14 11:37 AM One of the pleasures and pain of owning a manual. Never had 6060 box but had t56 and the noises,clunks,bangs & roll over that came out of that box. So in short it's normal.Ive owned a few t56 but none have been like this, I don't think its normal, all the other gears are fine just second. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 6m 7d Gender: Male Posted 30/04/14 11:56 PM Share Posted 30/04/14 11:56 PM It's normal, also comes down to how you drive, if you give it heaps the oil will go off quicker. I'm going to do a oil change next week will let you know if it helps or not. Link to comment Share on other sites More sharing options...
beastrado Member 23 Member For: 11y 2m 17d Posted 30/04/14 11:59 PM Author Share Posted 30/04/14 11:59 PM Cheers pazzo hope it sorts some of your issues out. What oil are you going to run? Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 6m 7d Gender: Male Posted 01/05/14 02:22 AM Share Posted 01/05/14 02:22 AM He will be using the Factory Dex3... But will put 4.8ltrs in not the 4.5lts. Others have done that and it helps. 1 Link to comment Share on other sites More sharing options...
Wingnut Member 573 Member For: 15y 8m 25d Gender: Male Posted 01/05/14 11:27 AM Share Posted 01/05/14 11:27 AM "It cant be normal""IT IS normal"Its a Ford... Its normal 1 Link to comment Share on other sites More sharing options...
Rollin Member 33 Member For: 15y 1m 20d Posted 16/05/14 01:14 PM Share Posted 16/05/14 01:14 PM Someone may have royally buggered up a gear change in the first 8000km and buggered the synchros in second gear.Hard to tell without driving the car and hearing the noise of course. Link to comment Share on other sites More sharing options...
