April 26, 201412 yr #1 I've heard the fg turbos have weak intercooler piping and need to be replaced due to the stock piping bursting.I was wondering at what power range will I need to change the piping?
April 26, 201412 yr #2 Haven't heard of burst pipe, occasionally hear of blown hose off the pipe due to bad clamps etc. if your making a million killawaps you've probably replaced the stock pipe anyway
April 26, 201412 yr #3 Have seen a burst pipe in person on a cruise in the early days of FG. Pretty killer
April 27, 201412 yr #4 Some peoples hold up fine, other ones burst later on from my research. Either way the material they are made of is thin and poor quality not something you'd expect out of a high performance car, so a good idea is to get a pipe kit and replace it.I'd say if your running anything more than factory boost, replace them. Edited April 27, 201412 yr by Z2TT
April 27, 201412 yr #5 Author If I decide to replace the piping, not the cooler just the piping, do I need a tune?
April 27, 201412 yr #7 No, the coolerworx and herrod replacement piping kits can be put on without a tune
April 28, 201412 yr #9 Yes straight fit as far as I know.I'm running 14psi through stock piping and cooler but that'll be changing real soon.
April 28, 201412 yr #10 Author oh nice, I was told if you increase boost, you need to change piping asap
