luke187 Member 297 Member For: 11y 7m 6d Posted 04/04/14 10:50 AM Share Posted 04/04/14 10:50 AM What issues are there when swapping ecus from another car? Is it just a case of swapping the ecus and getting ford to re-program it, as is done with the stereo, or is it more complex / I will lose functions on the car like smartshield or whatever its called now? Also will doing this write a default map to the ecu dropping the tune that's currently on it? Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/ Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 6m 4d Gender: Male Posted 04/04/14 11:03 AM Share Posted 04/04/14 11:03 AM Pretty sure u lose the aircon and all the multi function stuff and prob heaps of other stuff, trip computer and the like id imagine. I think ppl that have looked into it have found it not worthwhile unless making a super drag weapon Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463557 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 6d Posted 04/04/14 11:46 AM Author Share Posted 04/04/14 11:46 AM Is that swapping to an aftermarket ecu though? I just meant getting an ECU from one ba and running it in another. Im swapping a driveline from a stat writeoff and was hoping to swap the ecu from the engine in my car. Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463568 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 6m 4d Gender: Male Posted 04/04/14 10:15 PM Share Posted 04/04/14 10:15 PM Why r u swapping ecus? Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463600 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 6d Posted 04/04/14 11:48 PM Author Share Posted 04/04/14 11:48 PM As above. Driveline from a stat writeoff is going into the car, and ecu is staying with it. Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463606 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 15d Gender: Male Location: @ my laptop Posted 05/04/14 12:03 AM Share Posted 05/04/14 12:03 AM are you trying to save a custom tune in the ecu? Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463608 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 6d Posted 05/04/14 12:45 AM Author Share Posted 05/04/14 12:45 AM No, its a little confusing so that's why I didnt explain what im doing. In short im swapping a ba xr6 turbo driveline into a ba futura. The xr6 engine has id1000s on it so I wanted to keep the ecu with the engine. I'm getting a copy of vcm suite so can transfer the tunes through there, but I was hoping to get the car up and going before forking out the $900 for it.If its just a matter of getting it to ford to "reprogram" it to clear smartshield issues or whatever else comes about from an ecu swap, I'll do that as the it needs to go to ford anyway as I swapped a premium icc in and need the stereo security code cleared. Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463614 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 15d Gender: Male Location: @ my laptop Posted 05/04/14 01:26 AM Share Posted 05/04/14 01:26 AM have you spoken to the dealer about programming and what you need?Do you have the donor car?just swaping from one car to another, you may end up needing things like abs module, ignition and keys, icc etc Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463623 Share on other sites More sharing options...
luke187 Member 297 Member For: 11y 7m 6d Posted 05/04/14 09:48 AM Author Share Posted 05/04/14 09:48 AM I actually have 2 donor cars at the moment - one gold and one green. Originally I was just going to reshell the gold car with my futura swapping dash and wiring forward, diff, entire suspension (has bilsteins) and low ks, brakes, interior, exhaust etc - the whole shebang. Its also being converting to a manual so that's why the loom was going over, and since the gold one iis a mk2 id gain traction control and the most exiciting thing of all - auto headlights.Was just about to take the car off the road to go ahead with it when a much better car popped up with a lot of good gear on it, so im using the engine & bolt-ons, gearbox & diff from that now. Instead of using the ecu from the gold car in the swap, I was hoping I could use the green one that's suited to the "new" engine. Figured if they just need to reporgram it to accept the new ecu that's fine since I already have to take it to them to clear the security code error after swapping to a premium icc.. I'll call a dealer or 2 on monday, like I said if its going to be too complicated I'll just have to buy vcm suite first and transfer the tune over that way. Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463688 Share on other sites More sharing options...
miguel Donating Members 64 Member For: 16y 6m 27d Gender: Male Location: sydney Posted 05/04/14 10:02 AM Share Posted 05/04/14 10:02 AM Zhiixb 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87902-swapping-ecus/#findComment-1463693 Share on other sites More sharing options...
