naldz006 Member 61 Member For: 14y 6m 11d Gender: Male Location: Mallee Posted 16/02/14 07:22 AM Posted 16/02/14 07:22 AM Few different size hoses on fg. I got the impression somewhere on here in another thread that all the hoses were 10mm making it easy to plumb up. Mine took a bit more fiddling. The elbow off the pcv was about 7-8mm, the hose then stretches over the factory one way valve which is about 10mm, then shrinks back down to go into a 8mm t-join before stretching back out to 10mm go into the elbow connected to the intake manifold. The fittings on my catch can were 3/8 which is about 10mm, so I just went into ford and bought the larger elbow the same as what was connected to the intake manifold and swapped it with the one that was on the pcv, and bought a brass t-joiner that was 3/8 on either side. This allowed me to run 3/8 hose pretty much everywhere except the top bit of the t which I used 1/4" hose to plumb up to the rest of the factory line.
arronm Dropping a turd Legacy Donating Member 9,520 Member For: 18y 10m 27d Gender: Male Location: Perth Posted 16/02/14 09:57 AM Posted 16/02/14 09:57 AM Looks to me like you are pressurising the catch can and the PCV valve. Are you sure the one way valve is correct. Also the stock ones have been known to fail.
naldz006 Member 61 Member For: 14y 6m 11d Gender: Male Location: Mallee Posted 16/02/14 10:41 AM Posted 16/02/14 10:41 AM
naldz006 Member 61 Member For: 14y 6m 11d Gender: Male Location: Mallee Posted 16/02/14 10:43 AM Posted 16/02/14 10:43 AM Factory valve is still in place. Could only blow one way through it when I took it out to check it so it's not faulty as yet
barnz Member 3,047 Member For: 12y 10m 3d Gender: Male Location: Brisbane Posted 20/02/14 01:35 PM Author Posted 20/02/14 01:35 PM Yer it's hard to tell from the picks but the check valve(pcv) should be between manifold and canSent from my C6903 using Tapatalk
