January 14, 201412 yr #1 Decided to finally fix the miss fire I was getting under open throttle from 4.5k up in my ba typhoon. According to my mechanic it was the plugs and coils. However after putting a new set of delphi coil packs in and some plugs in it made the issue even worse. Has anyone else had a problem with delphi coil packs. I changed them over for vdo coils. Hopefully it will fix the issue when I put them in.
January 14, 201412 yr #2 So far u have bought the two chittest brand coil packs bar weapon x Repeat after me GENUINE COILS ONLY !!!!!!
January 14, 201412 yr #4 Author Cheers for the quick replys. Best place for genuine coils is the dealer im guessing? Has anyone had any luck with the vdo coil packs at all :s
January 14, 201412 yr #5 vdo were in my car and fine till they stuffed up similar to yours and I sold whole car anyway. ive heard of others running them.I still hear genuine are best
January 15, 201412 yr #6 Author Ok so I put the genuine ford ones in and the car is still miss firing very hard under load. Pretty sure the car is running very lean as a mate plugged in his diagnostic scanner ane the plugs showed signs of leaning out. Would that explain the issue.
January 15, 201412 yr #8 Author Tuned 330rwkw 15 psi. 60lb dekkas, 7 psi actuator. Hiflow cat etc. Was recently re tuned and serviced. Has been misfiring for a while but been getting worse and worse.
January 15, 201412 yr #10 Dude if u want u can bring it up the shed and we will spend some time with u and sort it out if u want ( I dont know who tuned your car and do not care but just offering free advice/help if your tuner wont )
