  • New Member
  • Member For: 13y 6m 12d
Posted
Hey guys,
driving home from work on the freeway I ended up having to quickly overtake someone in order to get off on my exit, naturally put the gearbox in performance and put the throttle down a little.
Car dropped more gears than suspected given throttle position then when I took my foot off the car started shuddering badly for ~15 seconds and the engine light turned on. Running a check on it later in the week but in the meantime, any suggestions? guessing it's gearbox/throttle sensor related.
Recently had my tranny coolant hose replaced due to wear and tear on the O-Ring, car also randomly backfires on start-up followed by an engine shut down quite rarely (happened 3 times in the last 3 months) or just won't start on the first time, have to take the keys out and turn it over again (more common).
08 bf mkii xr6t with a ZF auto
  • Member For: 14y 2m 8d
Posted
is it turbo on non turbo? either way id say TPS or coils
  • Here since the start...
  • Legacy Donating Member
  • Member For: 23y 5m 5d
Posted
  • New Member
Posted
yeah turbo, TPS is inside the accelerator isn't it? sealed unit?
