Banjora07 Member 66 Member For: 13y 7m 1d Posted 18/08/13 02:08 AM Share Posted 18/08/13 02:08 AM Hi I pulled out my icc to run a mechicnal boost gauge line when I went to connect everything nothing works I pulled the 4 out of the bottom and the big one in the middle only security fault came up at frist now nothing auto electron check it and said its not getting power and wants $800 to fix any ideas it's a 05 typhoon thanks Shaun Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/ Share on other sites More sharing options...
wombatG6ET Bronze Donating Members 707 Member For: 13y 2d Gender: Male Location: cherrybrook Posted 18/08/13 09:59 AM Share Posted 18/08/13 09:59 AM If you take them out and turn it on a big angle or upside down. It stuffs them Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416889 Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 16y 5m 8d Gender: Male Location: 720 East Kensington Road Posted 18/08/13 10:37 AM Share Posted 18/08/13 10:37 AM Bent pin in the main rear plug Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416917 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 21d Gender: Male Location: Probably above atmospheric pressure Posted 18/08/13 10:57 AM Share Posted 18/08/13 10:57 AM That $800 would be the cost of a brand spanker! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416920 Share on other sites More sharing options...
Banjora07 Member 66 Member For: 13y 7m 1d Posted 18/08/13 11:09 AM Author Share Posted 18/08/13 11:09 AM Nah no bent pin there all straight so I got no idea why it will not work Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416921 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m 27d Gender: Male Location: Christchurch, New Zealand Posted 18/08/13 11:15 AM Share Posted 18/08/13 11:15 AM Have you fully removed and refitted to check it. Also check fuses. Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416923 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 22d Gender: Male Location: Perth Posted 19/08/13 01:43 AM Share Posted 19/08/13 01:43 AM Did you reset the rear connector position before reinstalling? Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1416999 Share on other sites More sharing options...
Banjora07 Member 66 Member For: 13y 7m 1d Posted 19/08/13 07:39 AM Author Share Posted 19/08/13 07:39 AM Can u give me a little more info mate on the rear connecter position. Pls Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1417077 Share on other sites More sharing options...
Trent0 The Toxic Rocket Donating Members 574 Member For: 15y 1m 20d Gender: Male Location: Brisbane Posted 19/08/13 07:44 AM Share Posted 19/08/13 07:44 AM the white part of it should stick right out Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1417079 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 22d Gender: Male Location: Perth Posted 19/08/13 08:00 AM Share Posted 19/08/13 08:00 AM ^Whs,Pull the white part of the connector out and it will "click" this positions it int he correct position to slide into and lock into the ICC If you do reset it you can push it straight back and the connection wont be made413-08 Interior Command Centre.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/85993-icc-not-working/#findComment-1417085 Share on other sites More sharing options...
