Gtx3582R Actuator Bracket
Featured Replies
  • Author
What do you suggest then ratter?
  • Replies 25
  • Views 3k
Most Popular Posts
  • AzMahoony
    AzMahoony
    Hey guys I've ordered a GTX and was wondering for the guys who did a home install how you went about installing the actuator up. Did you utilize the standard bracket by somehow modifying it or was the
  • ScatterBrain
    ScatterBrain
    I made mine from 3mm mild steel plate.
  • I bought a universal bracket
checking it before using it and bracing it if required, it's probably not critical in 99.5% of cases, but depending on what other mods are on the car may lead to whether the wastegate works well enough to control the boost correctly
cheers for the advice Rattler, will have a good look at it once all set up.
save the hassle and go external :)
  • 1 month later...
*Update*
Just a couple of pics of the Garrett universal actuator bracket on the GTX turbo. The turbo is clocked into the exact position it needs to be and this is how the bracket looks. I have a straight actuator arm on my wastegate, and not sure if im going to use this one and maybe give the bracket a slight massage to straighten it up a bit as it kind of bends forward toward the front of the compressor at the moment. Or I may end up swapping it for an actuator that already has a pre-bent arm on it. Not sure what way I will go just yet il do some measuring tomorrow and see if a straight arm will work or not.
Anyway some pics for you guys to see.
Garrett bracket part number: 773161-0002
The pictures are deceaving, it looks like there is a big bend needed in the rod, but its not as much as it looks in some pics. Im thinking a small massage on the bracket and small tweak in the rod and it will fit just fine. Not 100% sure what il do at this time, if the turbo company lets me swap it for the bent arm, il probably swap it, but if they dont, im sure I can make this work.
Edited by BlueOvalPower
Recently Browsing 0
