July 22, 201313 yr #22 Zf= no probs with clutch pedal!Zf=Broken input shaftsMilkshakesBullshit expensive servicesBullshit expensive electronic control systems Bullshit annoying sqaurks on downshifts But I digress See my previous post pazza.
July 23, 201313 yr #23 Author Did what you told me to do and nothing happened..no creeping or anything..
July 23, 201313 yr #27 If you do need a new Master call Malwood as they do they for a lost less than fraud.
July 23, 201313 yr #28 My XR8 did this.. there is a radial spring that pulls the clutch arm back up... the spring is known to break. its right at the top of the clutch arm at the pivot. I'd put $1 on it. look under your mat or near the front of the seat base for a bit of wire in a loop about 2-3mm in dia...ANDout of warranty its about $4-500 in labour to do.."dash out mate" ford told me... Edited July 23, 201313 yr by Chaos310
July 23, 201313 yr #30 does the same dealer tell you that you must remove the fuel tank to put fuel in it?
