Azid Member 213 Member For: 12y 7m 13d Posted 07/05/13 04:07 AM Share Posted 07/05/13 04:07 AM Hey guysJust wondering if anyone is using the HDI kit belowhttp://www.ebay.com.au/itm/HDI-HYBRID-X01-R-FRONT-MOUNT-INTERCOOLER-KIT-FORD-FALCON-BA-BF-XR6-F6-TYPHOON-/310651346916?pt=AU_Car_Parts_Accessories&hash=item4854435fe4If so do they go alright? Would they cause overboost without tune? Are these the cheapest they go for or is there cheaper place?Any info appreciatedCheers Link to comment Share on other sites More sharing options...
pejamas Member 2 Member For: 16y 1m 28d Posted 07/05/13 06:21 AM Share Posted 07/05/13 06:21 AM I'm curious to find out as well, been considering something like this. Link to comment Share on other sites More sharing options...
HDI-XR6 Member 58 Member For: 15y 5m Gender: Male Location: Sydney Seven hills Posted 07/05/13 07:25 AM Share Posted 07/05/13 07:25 AM Dear AaronThanks for your message that looks like a BA intercooler kit Hdi intercooler kit is not the cause of overboosting, standard intercooler kit has 6 psi restriction HDi X01-R is a very high flow intercooler which reduce lots of the restriction, the best option is to tune it first and then change the intercooler kit to get the maximum performance.any question please let us know thanks Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 11m 4d Gender: Male Location: @ my laptop Posted 07/05/13 08:03 AM Share Posted 07/05/13 08:03 AM it should be tuned after the cooler goes on, not before hand 4 Link to comment Share on other sites More sharing options...
aza_w64 Member 46 Member For: 11y 27d Gender: Male Location: Dandenong Posted 07/05/13 08:20 AM Share Posted 07/05/13 08:20 AM You tell em Ratter! Link to comment Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 11y 8m 4d Gender: Male Location: Sydney Posted 07/05/13 09:21 AM Share Posted 07/05/13 09:21 AM yes, doesnt the fact that it is less restriction mean that it WILL possibly cause overboost?seems pretty common sense to tune with all the hardware on the car already. Link to comment Share on other sites More sharing options...
Azid Member 213 Member For: 12y 7m 13d Posted 07/05/13 06:51 PM Author Share Posted 07/05/13 06:51 PM So this kit would be no good if there's no tune in the near future? Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 13y 6m 12d Posted 07/05/13 11:25 PM Share Posted 07/05/13 11:25 PM ^^ Just depends but being such a big change from stock it's worth at least going to a shop to get afr's, overboost etc checked Link to comment Share on other sites More sharing options...
HDI-XR6 Member 58 Member For: 15y 5m Gender: Male Location: Sydney Seven hills Posted 12/05/13 02:38 PM Share Posted 12/05/13 02:38 PM yes, doesnt the fact that it is less restriction mean that it WILL possibly cause overboost?seems pretty common sense to tune with all the hardware on the car already.When restriction is removed the boost will raise , then the boost sensor will pick it up , and the computer will make adjustment to reduce the boost. however every engine may have different VE and if the boost adjustment is over the factory parameter it will light up the engine light. and yes you can tune after all the hardware goes on as well that is for custom tune .most of the flash tuning device are using preset parament for most of the car therefore. you can remove lots of limiter before putting the intercooler kit in too . Link to comment Share on other sites More sharing options...
sct911 Member 848 Member For: 11y 5m 25d Gender: Male Posted 12/05/13 05:12 PM Share Posted 12/05/13 05:12 PM hdi are your kits tube and fin or bar and plate? anyone know what type rapids is? I know PW is bar and plateinteresting read:The Core IssueOne thing the Banks Power engineers have learned is that extruded-tube intercoolers work better in real-life setups, because space constraints require intercoolers to be placed in front of the engine’s radiator. Bar and plate intercooler cores have been shown to restrict flow through the radiators, which can cause the engine computer to reduce fueling (and performance), due to a lack of cooling. Another element of the intercooler that restricts flow is the cooling fins between the core tubes because of how tightly they are packed. While more fins equals more cooling, it also means less air can flow through for use by the engine and its heat exchangers. As Banks put it, “make the intercooler too efficient, and it ends up being totally selfish, starving the rest of the cooler pack, which needs air, causing those systems to overheat.”Read more: http://www.dieselpowermag.com/tech/1304dp_intercoolers_how_they_work/#ixzz2T61myi7Q 1 Link to comment Share on other sites More sharing options...
