  • Legacy Donating Member
  • Member For: 22y 11m 7d
Posted
I will go back to the dealer on Monday
Does anyone know why sometimes the turbo doesnt kick in ? :unsure::bigdrool:
Yes it does have a turbo ;)
Getting first
Thanks
rapt :ta:
  • Replies 32
Posted
or maybe I should turn the key on :censored:
  • Member For: 23y 4m 20d
Posted
Hi ho Hi Ho off to the dealer we go..... :(
  • Toughest BA Turbo
  • Member For: 23y 8m 28d
Posted
Without a boost gauge how do you know the turbo is not boosting?
Usually with other cars I get little or no boost only if there is an exhaust leak, which you should be able to hear.
If it's down in power it may be some non-turbo related problem.... so take it back.
Brian
  • SLOJAM, Gone but not forgotten
  • Member For: 23y 11m 11d
Posted
Ummm, you are not hitting 2700rpms.....
I thought the turbo reached boost at 2000rpm, thus the reasonably flat torque curve from there up to the rev limiter :censored:
  • Toughest BA Turbo
Posted
Richdave,
My old dyno graph of the car when stock shows max boost of 6psi at 90kph, which is around 2800 revs in 4th gear. It had 4psi at 80kph (2500 revs).
Brian
  • Member For: 23y 6m 14d
Posted
Rapt, you may have a sticky swing valve in the turbo housing, this can cause normal boost and then complete loss of turbo pressure. We saw ths problem on an xr6t in december and sorted the problem after the vehicle had been back to ford on 5 occasions. Need less to say the owner was stocked when we sorted the problem.
Peter
APS
Posted
Thanks very much Pete that was the was the sort of responce I was wanting to get :kissmy:
A well informed educated post not like some other Richard heads :finger:
