The Falcon Legacy Donating Member 22 Member For: 15y 8m 3d Posted 16/02/13 05:51 AM Author Posted 16/02/13 05:51 AM The Clutch is a RPM twin plate. After you fit the new gearbox make sure the slip yoke and the tailshaft are in line. I needed to drop the centre of the tailshaft 22mm using spacers I made from some solid alloy rectangle bar. The output shaft of the new gearbox sits around 20mm lower than the T5Z.You could do it in a weekend if all goes well. It took me hours to get the old slipyoke of the tail shaft. I asked questions and waited for answers on a few things so this dragged it out over a couple of weeks.Its worth doing. Its a different car to drive,Let me know if you need any information on doing the conversion.Greg
Paulie2256 Legacy Donating Member 7,441 Member For: 17y 10m 13d Gender: Male Location: SE Melbourne Posted 16/02/13 07:20 AM Posted 16/02/13 07:20 AM You should change to a 3.73 diff. Way better.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 21y 12d Gender: Male Location: Perth Posted 16/02/13 07:21 AM Posted 16/02/13 07:21 AM ^whs
OED666 Member 129 Member For: 20y 3m 11d Gender: Male Location: Gold Coast, Qld Posted 16/02/13 08:52 AM Posted 16/02/13 08:52 AM All the factory turbo's with the T56 have 3.73's... I just remembered that Greg has a TR-6060 and they do have different ratios to BA/BF T56's. In the long run, 3.73's would be a good choice. Make sure you don't use 5th unless you are doing 80km/h at a minimum on a flat road, and 6th only at 100+. If the car is labouring, go back a gear. All going well, we do this conversion at work in about 5 hours.
The Falcon Legacy Donating Member 22 Member For: 15y 8m 3d Posted 16/02/13 11:02 AM Author Posted 16/02/13 11:02 AM Thank,Paul did say to make sure the car was not labouring in 5th and 6th. I will be rebushing the rear end in the next 6 months so I will look into changing the diff to 3.73 at the same time.Greg 1
fehlbie Legacy Donating Member 142 Member For: 17y 6m 4d Posted 21/02/13 06:03 AM Posted 21/02/13 06:03 AM I think you'll find the rattle is coming from the TR6060. If you disengage the clutch does the rattle go away? If so it isn't the clutch, apparently the Lay shaft in the TR6060 makes the noise, mine has from pretty much day dot.
OED666 Member 129 Member For: 20y 3m 11d Gender: Male Location: Gold Coast, Qld Posted 21/02/13 10:02 AM Posted 21/02/13 10:02 AM I think you'll find the rattle is coming from the TR6060. If you disengage the clutch does the rattle go away? If so it isn't the clutch, apparently the Lay shaft in the TR6060 makes the noise, mine has from pretty much day dot.This transmission should be quiet, as the transmission has been blueprinted.
The Falcon Legacy Donating Member 22 Member For: 15y 8m 3d Posted 22/02/13 05:10 AM Author Posted 22/02/13 05:10 AM It only rattles while the car is sitting at idle. Push in the clutch and the rattle goes away.
oplock27 Member 36 Member For: 13y 10m 16d Gender: Male Posted 03/05/13 12:42 PM Posted 03/05/13 12:42 PM Greg, once the 31 spline slip yoke is installed was the BA tail shaft still right length to use with t56. Is it just the centre bearing height to adjust?
