Bf Leaking Aircon Water
Featured Replies
#1
Hi all I have done a search with no results
My problem is I went for a drive today 30min max with aircon on I pulled up back home and I felt the drivers side tunnel carpet was very wet checked passenger side dry as a bone everything is working as it should so im thinking heater core the car has 88,000km on it
any advice is greatly appreciated.
#2
Air con drain will be blocked.
You'll need to get under the car and stick a bit of wire into the outlet to clear it. You'll find the outlet above the front of the trans.
#3
  • Author
I really hope it's just that I don't like the fact I might have to remove dash.
Thanks for that I'll give it a shot
#4
You'd notice the smell if it was coolant.
It won't be easy getting to the drain with the car on the ground. Use a hoist if you can get access to one.
#5
drain tube bro ^^^^ what they said
#6
  • Author
Thanks guys.. How do they get blocked?
#7
Had that happen to my BA or BF in the past (don't remember which one). It was blocked drainage as well. Mine was on the passenger side though - came down like a waterfall after the air-con was blowing out like a fine mist (was so humid at the time). Hope it's as simple as that :thumbsup:
#8
  • Author
Got it on the hoist today used the air blower and some wire nothing came out so I'm hoping it's all good will give it a couple days if not then dash out time and I might as well replace heater box :(
#9
What happens is the drain tube is not big enough to drain all the condensation and it spills out past the foam heater core seal, there is a seal kit available from ford that fixes the issue, comes with instructions and takes about half an hour to do. Should fix the issue
#10
  • Author
Thanks for that will give for a call tomorrow
Recently Browsing 0
